Cisco CNC (Central Network Controller) Software
muhammetonur
I am trying to use TSN feature on Cisco IE 4000 switch. According to TSN documentation for IE 4000,  I need to use a CNC software which is provided by Cisco in order to create TSN schedules. However, I can't find any information about installing this software. Also in switch console I saw that I can configure TSN on switch either by using a CNC server or by providing a JSON file. How can I find the structure for this JSON file?
Albert Mitchell
hello,
before releasing the Cisco CNC reference application, please answer these questions
 which company do you represent?
what is your intended purpose for using the TSN feature?
Cisco TSN only supports 802.1Qbv.  what types of end devices do you have?  (they must support Qbv)
DamirHamidovic
I have the same problem as Mohammedour explained.
I am an employee of Silicon Austria Labs GmbH, Austria. I am working there as a scientist and the purpose of usage of TSN features is for research in the area of industrial time-sensitive applications, where guaranteed latency is required.
How could I get the CNC software and the installation/usage guide?
Thank you
Best Regards,
Damir Hamidovic
