Catalyst IE3200 NAT
ehouston
Does the Catalyst IE-3200-8T2S-E support NAT. I was told this device supports NAT pre-sale and it appears it does not after configuration.  If it does not support NAT is there a firmware upgrade to add this feature?
Albert Mitchell
IE3200 does not support L2NAT.
the datasheet does not claim support.  the IE3300 and IE3400  support L2NAT.
None of the IE3200/3300/3400 support NAT with Layer4 port address translation(PAT).
L2NAT is IP address translation only used for 1:1 public to private.  if you requier 1:N public to private teh IE switches do not support
Thanks Albert, I appreciate the confirmation. This is a hardware constraint correct?
yes, that is what the document describes.(have you got a chance to look the document provided in the post ?)
BB
