Cisco IG20R Rugged Series IoT Gateways
rpatel1
I have been researching Cisco IG20R Rugged Series IoT Gateways and other similar models. I wanted to know if we can control the devices (example PLCs) connected to the IoT Gateway or we can only monitor the status of the device. I am looking to buy an IoT Gateway where I can both control and monitor the device connected to the gateway. The device would mostly be a Allen Bradley PLC.
Can you answer this or connect me with someone who can answer this?
2 Accepted Solutions
gauraaga
When you connect a PLC behind IoT Gateway, you will have regular IP connectivity to it. So you can both monitor and control the PLC.
Gaurav
Yes, IoT Operations Dashboard is a browser-based dashboard that is offered as a cloud service. You can access it as https://us.ciscoiot.com
Gaurav
gauraaga
Gaurav
Thank you for your reply. Is the Cisco IoT Operations Dashboard a browser based dashboard, or would we have install the software in PC? I want to see if I can directly access the dashboard using the internet.
Thank you.
Gaurav
Thank you for your response.
