Cisco PIX 515E help
RadxD461
Hi, I collect vintage Cisco networking equipment. I have a Cisco PIX 515E.I can't seem to reach the outside internet with it. Here is my config: RDXLFW1# sh ru
: Saved
PIX Version 7.2(2)
hostname RDXLFW1
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Ethernet0
 nameif outside
 security-level 0
 ip address 192.168.1.80 255.255.255.0
interface Ethernet1
 nameif inside
 security-level 100
 ip address 10.0.0.1 255.255.255.0
interface Ethernet2
 shutdown
 no nameif
 no security-level
 no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
pager lines 24
logging buffered debugging
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 192.168.1.81-192.168.1.135 netmask 255.255.255.0
global (outside) 1 192.168.1.51
nat (inside) 1 10.0.0.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.0.0.10-10.0.0.110 inside
dhcpd enable inside
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:60f7cdd469e5a489e44e1759abedd3cb
: end
RDXLFW1#
liviu.gheorghe
Hello @RadxD461 ,
can you provide the output of the following commands after you try accessing the Internet:
show nat detail
show conn all
Regards, LG
*** Please Rate All Helpful Responses ***
I figured out the issue. It was a DNS issue.
