05-08-2014 11:24 AM
I am trying to create an AMQP Broker target in CPO 3.0. I am getting an error "None of the specified end points were reachable". I have RabbitMQ installed on the local host and I am able to exchange messages using Java clients and the default virtual host. Anyone has suggestions as to what could be the potential problem here. See the attached snapshot.
Ayaz
Solved! Go to Solution.
05-08-2014 02:54 PM
Besides what David pointed out, please double check the port and credentials you used to connect to RabbitMQ. RabbitMQ doesn't report authentication error as it should. All the connection errors will be shown as "None of the specified end points were reachable".
James
05-08-2014 12:07 PM
Ayaz,
Make sure the runtime user matches the user register in RabbitMQ (case sensitive). If that didn't solve the "None of the specified end points were reachable" change the localhost to the actual hostname or IP 4 address.
David.
05-08-2014 02:54 PM
James
05-09-2014 11:32 AM
Thanks James. I had to register the CPO runtime user in RabbitMQ and grant the default permissions and it worked.
Ayaz
