Bookmark
Subscribe
576
which browser does tidal use to load runbook URL? how to check browser version
we are planning to migrate to sharepoint list runbook. When I load the sharepoint url in runbook tab, it loads up perfectly. When I click on hyperlink on the page, I am getting run-time script pop-pup - "An error occured in script on this page"- class not registered (Loaded scriptFiles undefined-microsoft Jscript runtime error).
This clickable link in page works perfectly in IE or chrome. I want to know which browser and version tidal is using. How to check this?If I were to change the settings of this browser where should I do it. Or if anyone encountered similar issue, please suggest the fix.
Thank you!
0 Replies 0
