10 Analogue Co Lines
yeminwin123
I have a customer who has 10 Analogue CO lines and want to go for VOIP infrastructure for their call center application.
Kindly suggest me the suitable products to host 10 analogue CO lines.
Thanks in advance.
Rajan
You can go with any of the below VGs with modules like Cisco VIC2-4FXO
http://www.cisco.com/c/en/us/products/unified-communications/vg-series-gateways/index.html
http://www.cisco.com/c/en/us/td/docs/routers/access/vg310_vg320/hardware/installation/guide/bm_vg310_vg_320_voice/bm_vg310_vg_320_voice_chapter_01.html#concept_DA6FB7475846411399E257410CE149FF
If you want to go with the higher end models, then go for any ISR and select the appropriate modules.
Rajan
