2 VM box for a user in unity connection
raviah1107
hello
I need to know if creating 2 voice mail box for a user is possible where his request is as below
User request that when he goes for a days leave the caller shall be able to reach his VM box with greeting and shall be able to leave a message and the second case is
where user goes for a long time vacation where he wants that the caller shall hear only the greeting message and shall not be in position to leave a Voice mail
Please assist
Rgds
Ravi
2 Accepted Solutions
barry
Level 7
Level 7
Hi Ravi
Each directory number (user) can only have a single voicemail box. However, each voicemail box can have multiple greetings. Commonly users record an alternate greeting for times when they are on holiday and activate that when they are away. When they return from vacation they deactivate the alternate greeting and revert to their standard one.
One additional step you could take would be to change the "after greeting" action on the mailbox to "Hang Up" from the default of "Take Message" when they go away on vacation.
Barry Hesk
Intrinsic Network Solutions
Hi Ravi.
Admin should only modify the behaviour of alternate greeting one time so the user can choose if he wants to receive message in his mailbox or not activating or deactivating the alternate greeting
User has the ability to activate and deactivate the alternate greeting and he can record a new one mantaining the behaviour configured by admin.
Carlo
Please rate all helpful posts
Please rate all helpful posts "The more you help the more you learn"
6 Replies 6
barry
Level 7
Level 7
Hi Ravi
Barry Hesk
Hello Barry
Thanks for sharing this,
Could you please help me understand as from user perspective how user can do this.
Also from Admin point what all config we can do to facilitatie user in both the conditions .
Thanks..
Ravi
Hi Ravi.
From admin prospective, you have only to change the alternate greeting behaviour as Barry suggested (+5P Barry).
From user point, he has to access his voice mail, navigate the menu to VM settings and activate and deactivate the alternate greeting.
Steps for user:
Voicemail button
PIN
key 4
key 1
key 2 to activate and deactivate the message.
Carlo
Thanks Carlo
From user and admin prospective I mean that if both the changes need to be done simultaneously ??
What I am looking for is that user shall be able to change the greeting of his own without requesting admin, as mentioned by barry above ( action on the mailbox to "Hang Up").
So could you please confirm that as an admin what is the one time configuration that shall be done so that user is able to proceed with the change as mentioned by you above following the steps mentioned below when ever he wish to
"Steps for user:
Voicemail button
PIN
key 4
key 1
key 2 to activate and deactivate the message"
Thanks..
Hi Ravi.
Carlo
yes yes yes .. it works !!!!!!
Thanks carlo and barry for your such a great help ...
Rgds
Ravi
