2020 Jabber Chromebook compatibility
carltonjo
There was a post about Chromebooks and Jabber from 2019 but with newer versions of Jabber out there is there an updated list of what Chromebooks, if any are compatible with it?  With COVID and working from home we're becoming dependent on Jabber for it's phone capabilities.  But we're also looking at Chromebooks to cut costs for remote workers.  Just curious if people are having success with any specific model of Chromebook with Jabber 12.9.1.
Thanks in advance!!
Jaime Valencia
Jabber documentation contains the HW compatibility for each Jabber release, have you reviewed it?
java
if this helps, please rate
Thanks for the reply.  I feel stupid that I didn't check that first so after reading your reply I did.  I see nothing in the 12.9 or 12.8 notes referring to Chromebooks.  I'm sure I could be looking at the wrong thing.  If you have a link would you mind sharing it?
See requirements chapter from planning guide
https://www.cisco.com/c/en/us/support/unified-communications/jabber-windows/products-installation-guides-list.html
java
