2811 Cube [h323-sip] one way voice
fazlayrabby
Hi all,
I am trying to configure a CUBE using 2811 router as below:
CUCM........<h323>.....CUBE......<sip>......IPTSP
When making outgoing call from IPphone I can hear the other party, but voice from inside is not going through.
Detail:
IPTSP prefered codec: G729
CUCM setup:
MTP: checked
Region: G729 set for the Gateway DP
CUBE setup:
see attach file.
Here is the SIP-UA call info:
SIP UAC CALL INFO
Call 1
SIP Call ID                : DC2D2FF4-C0ED11E0-806AD6A3-7DBA46EC@202.84.46.142
   State of the call       : STATE_ACTIVE (7)
   Substate of the call    : SUBSTATE_NONE (0)
   Calling Number          : 09604107000
   Called Number           : 01713037716
   Bit Flags               : 0x101A0030 0x100000 0x400
   CC Call ID              : 207
   Source IP Address (Sig ): 202.84.46.142
   Destn SIP Req Addr:Port : 202.126.120.100:5060
   Destn SIP Resp Addr:Port: 202.126.120.100:5060
   Destination Name        : 202.126.120.100
   Number of Media Streams : 2
   Number of Active Streams: 1
   RTP Fork Object         : 0x0
   Media Stream 1
     State of the stream      : STREAM_ACTIVE
     Stream Call ID           : 207
     Stream Type              : voice+dtmf (0)
     Negotiated Codec         : g729r8 (20 bytes)
     Codec Payload Type       : 18
     Negotiated Dtmf-relay    : rtp-nte
     Dtmf-relay Payload Type  : 101
     Media Source IP Addr:Port: 202.84.46.142:18624
     Media Dest IP Addr:Port  : 202.126.120.100:6232
     Orig Media Dest IP Addr:Port : 0.0.0.0:0
   Media Stream 2
     State of the stream      : STREAM_IDLE
     Stream Call ID           : -1
     Stream Type              : voice+dtmf (1)
     Negotiated Codec         : No Codec    (0 bytes)
     Codec Payload Type       : 255 (None)
     Negotiated Dtmf-relay    : inband-voice
     Dtmf-relay Payload Type  : 0
     Media Source IP Addr:Port: 202.84.46.142:18734
   Number of SIP User Agent Client(UAC) calls: 1
SIP UAS CALL INFO
   Number of SIP User Agent Server(UAS) calls: 0
Debug CCsip error:
*Aug  8 12:07:45.484: //-1/xxxxxxxxxxxx/SIP/Error/sipsdp_add_standard_lines: media_src_address is NULL; c-line is not added
SIP: Attribute ptime, level 1 instance 1 not found.
*Aug  8 12:07:45.540: //207/8048FA320A00/SIP/Error/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Aug  8 12:07:45.568: //207/8048FA320A00/SIP/Error/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Aug  8 12:07:45.572: //207/8048FA320A00/SIP/Error/sipSPISetStreamInfo: Number of active streams is zero (0)!
*Aug  8 12:07:50.020: //207/8048FA320A00/SIP/Error/sact_active_new_message_response: Invalid response for active call, dropping it
Debug CCsip Message: See attached
Please advise what I am doing wrong. Many thanks in advance.
Fazlay
fazlayrabby
Thanks all. I have done some improvement and it is working with some flaw. No need to answer this thred.
