2811 - VIC2-2FXS - No Dial Tone
Denis
Hi!
We have faced an issue with the FXS port on our 2811 gateway with IOS ver Version 12.4(24)T2.
There is an analog phone connected to the port with the default settings stated below.
If I pickup the phone I cannot hear the dial tone, there is only noise.
Foreign Exchange Station 0/2/0 Slot is 0, Sub-unit is 2, Port is 0
Type of VoicePort is FXS VIC2-2FXS
Operation State is DORMANT
Administrative State is UP
The Last Interface Down Failure Cause is Administrative Shutdown
Description is not set
Noise Regeneration is enabled
Non Linear Processing is enabled
Non Linear Mute is disabled
Non Linear Threshold is -21 dB
Music On Hold Threshold is Set to -38 dBm
In Gain is Set to 0 dB
Out Attenuation is Set to 3 dB
Echo Cancellation is enabled
Echo Cancellation NLP mute is disabled
Echo Cancellation NLP threshold is -21 dB
Echo Cancel Coverage is set to 128 ms
Echo Cancel worst case ERL is set to 6 dB
Playout-delay Mode is set to adaptive
Playout-delay Nominal is set to 60 ms
Playout-delay Maximum is set to 1000 ms
Playout-delay Minimum mode is set to default, value 40 ms
Playout-delay Fax is set to 300 ms
Connection Mode is normal
Connection Number is not set
Initial Time Out is set to 15 s
Interdigit Time Out is set to 10 s
Call Disconnect Time Out is set to 60 s
Supervisory Disconnect Time Out is set to 750 ms
Ringing Time Out is set to 180 s
Wait Release Time Out is set to 30 s
Companding Type is u-law
Region Tone is set for US
Analog Info Follows:
Currently processing none
Maintenance Mode Set to None (not in mtc mode)
Number of signaling protocol errors are 0
Impedance is set to 600r Ohm
Station name Test, Station number 63278
Caller ID Info Follows:
Standard BELLCORE
Output attenuation is set to 14 dB
Caller ID is transmitted after 1 ring(s)
Translation profile (Incoming):
Translation profile (Outgoing):
Voice card specific Info Follows:
Signal Type is loopStart
Ring Frequency is 25 Hz
Hook Status is On Hook
Ring Active Status is inactive
Ring Ground Status is inactive
Tip Ground Status is inactive
Digit Duration Timing is set to 100 ms
InterDigit Duration Timing is set to 100 ms
Hookflash-in Timing is set to max=1000 ms, min=150 ms
Hookflash-out Timing is set to 400 ms
No disconnect acknowledge
Ring Cadence is defined by CPTone Selection
Ring Cadence are [8 32] * 100 msec
Ringer Equivalence Number is set to 1
The port has all necessary configuration:
voice-port 0/2/0
station-id name Test
station-id number 63278
caller-id enable
dial-peer voice 63278 pots
destination-pattern 63278
port 0/2/0
forward-digits all
dial-peer voice 1 voip
description *** Outgoing SIP to CUCM***
preference 1
destination-pattern .T
voice-class codec 1
session protocol sipv2
session target ipv4:10.1.1.1
voice service voip
fax protocol cisco
sip
bind control source-interface Loopback237
bind media source-interface Loopback237
voice class codec 1
codec preference 1 g729r8
There is a SIP trunk towards this gateway configured on CUCM and the appropriate Route Pattern used for the phone extension.
When we call to that extension we can hear the dialing and waiting for the answer, but the phone on the test site is not ringing.
At the same time I can see that it is ringing according to the output:
show voice call status
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0xCA 1 0x4922E944 0/2/0 0/1:1 *63278 g729r8 1/63278
1 active call found
There is available DSP resource:
DSP DSP DSPWARE CURR BOOT PAK TX/RX
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABORT PACK COUNT
----------------------------FLEX VOICE CARD 0 ------------------------------
*DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND : (bad)bad (shut)shutdown (dpend)download pending
TYPE NUM CH CODEC VERSION STATE STATE RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g729r8 24.3.2 busy idle 0 0 0/2/0 00 0 704/26
*DSP SIGNALING CHANNELS*
C5510 001 01 {flex} 24.3.2 alloc idle 0 0 0/2/0 02 0 1854/0
C5510 001 02 {flex} 24.3.2 alloc idle 0 0 0/2/1 02 0 3935/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
What have been done?
I tried shut no shut, tried the second Voice Port - the same issue.
Tried another Phone - the same.
Tried to test with the verified cable - the same.
Could it be the faulty VIC2-2FXS card?
I would greatly appreciate it if you kindly provide some suggestions.
Regards, Denis.
6 Replies 6
acampbell
Hi Denis
In the first instance you need to prove your wiring.
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/7938-2fxs-vic.html
The FXS port on the router needs only a 2 wire connection to the phone.
Router FXS RJ11 - PIN 3 ----------- PHONE RING
Router FXS RJ11 - PIN 4 ----------- PHONE TIP
Just connect these wires only and re-test
Alex
Regards, Alex. Please rate useful posts.
Hi Alex,
thanks for reply. The thing is that the cable was verified. We have another location with the same set up and used that cable & phone to test the connection there. That is why I have no doubt about it.
Regards, Denis
I was able to perform a test with the following commands:
test voice port 0/2/0 detector ring-trip on
test voice port 0/2/0 loopback network
I called to the problem destination phone and got the call answered by the gateway, then I looped the call so i could hear myself. So at least now I know that the DSP is working properly.
Additionally I made one more test, I picked up the phone and could see in the debug that the gateway is actually generating the Dial Tone:
002712: Mar 25 2016 16:38:22.918 : //244/ADA75D2F82D9/CCAPI/ccGenerateToneInfo:
Stop Tone On Digit=TRUE, Tone=Dial Tone,
Tone Direction=Network, Params=0x0, Call Id=244
002723: Mar 25 2016 16:38:22.922 : //244/ADA75D2F82D9/VTSP:(0/2/0):-1:1:1/act_setup_ind_ack:
Fax Relay=TRUE, Dial Tone=TRUE, Digit Collect=TRUE, Overlap=FALSE, DID=FALSE
show dial-peer voice summary
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT
63278 pots up up 63278 0 up 0/3/0
63279 pots up up 63279 0 up 0/3/1
1 voip up up .T 1 syst ipv4:10.2.1.6
2 voip up up .T 2 syst ipv4:10.2.2.6
The problem has been solved by reinstalling the vic2-2fxs card to another available slot.
