IP Telephony and Phones
Personalize banner_3
Labels
Hi everyone, We deployed on our company the ToIP system, we need keep some old analog phone, so we deployed some ATA 187 and 190. Our problem is the following: We have 2 analog lines behind 1 ATA 190, each line is connected to a modem, in order to ...
abecquet-LP by Community Member
  • 4824 Views
  • 3 replies
Hello,   WE ordered Cisco NAME: "CISCO2911/K9", DESCR: "CISCO2911/K9 chassis, Hw Serial#: FCZ201070FU, Hw Revision: 1.0" PID: CISCO2911/K9      , VID: V07 , SN: FCZ   We are planning to connect  FXS card on it to configure Analog FAX machine  below ...
Dear All, One support related call routed to PRI DID number to be rerouted to another PRI DID number with out routing from the source. Scenario : All call for 800 XXXX will be landing a Pri number # XXXXX 802 should be routed to another PRI DID #XXXX...
In CME 8.6, what if tftp debug shows a missing CTLSEPXXXXXXX.tlv file, causing a tftp time out/loop on the 7940? Jul 23 01:03:25.723: TFTP: Looking for CTLSEPXXXXXXXX.tlvJul 23 01:03:25.723: TFTP: Sending error 1 No such file
Has anyone encountered a problem with MS UM (2010, with I think service pack 3) where in an auto attendant you can't press an option to transfer to an extension back on the Cisco UCM?  I'm at version 10.5 for CUCM.  I can press 0 to transfer back to ...
voip7372 by Level 9
  • 2328 Views
  • 4 replies
