2900 FXO Port remains in off-hook after call
eran moyal
Hello
I have a 2900 router with FXO ports running Cisco IOS Software
c2900-universalk9-mz.SPA.151-4.M5.bin .
The problem is when the call is ended and we hung-up, port remains in off-hook and the line remains busy for long time.
5 Replies 5
yahsiel2004
Level 7
Level 7
Can you post your GW configuration and what version of CUCM\CUCME you're using?
Yosh
HTH Regards, Yosh
CUCM 8.6.2.23900-10
Do you need all configuration or voice port?
voice-port 0/0/0
trunk-group PSTN
cptone IL
timeouts call-disconnect 1
timeouts wait-release 1
connection plar 58694150
impedance complex2
caller-id enable
voice-port 0/0/1
trunk-group PSTN
cptone IL
connection plar 58694151
impedance complex2
caller-id enable
voice-port 0/0/2
trunk-group PSTN
cptone IL
connection plar 58694152
impedance complex2
caller-id enable
Eran,
Depending on where you're, there can be many options for detecting a call disconnect. Check out the links below, they should help you.
Cisco FXO options:
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did-fxs-fxo/8120-fxo-disconnect.html#topic3
Tone database:
http://www.3amsystems.com/wireline/tone-search.htm
Yosh
HTH Regards, Yosh
when calls going out through the fxo ports everything is ok  after the calls  disconnect
the fxo go to on hook mode .
when calls coming in through the fxo port after the call disconnect the port is still in off hook mode for 7 minutes .
up
