2921 EVM-HD-8FXS/DID first two ports go into FXSLS_PARK state
John Watkins
Level 4
Level 4
We are currently in a rollout of ~200 locations in which we are deploying 2921's with EVM-HD-8FXS/DID, EVM-HDA-8FXS/DID, and PVDM3-64 we are running IOS 15.1(2)T3,. The 2921 interconnects our KSU, modems, faxes from a SIP trunk provided by our carrier. We currently have ~24 locations deployed over the last 2 months and are starting to see an issue (currently 3 locations) in which port 1/0/0 and 1/0/1 get stuck in a FXSLS_Park state, it's important to note, that these two ports take a majority of the calls. Occasionally a reboot of the router will resolve the issue (shut/no shut does nothing), but now even a reboot is not resolving the issue. We have also disconnected the amphenol cable that runs to the existing equipment and shut/no shut, reloaded the router and the port still continue to come up in a FXSLS_Park state. it's important to note, that these locations were early deployed locations and have been running fine for over a month and then progressively got worse. If this is a hardware issue, that concerns me, an 12% failure rate is not acceptable.
Any suggestions you can provide with be greatly appreciated!
KSU ---2921 ---- SIP Trunk ---- PSTN.
show ver:
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(2)T3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 10-Mar-11 15:57 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
r06242 uptime is 8 hours, 57 minutes
System restarted at 01:44:48 cst Fri Oct 19 2012
System image file is "flash:c2900-universalk9-mz.SPA.151-2.T3.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2921/K9 (revision 1.0) with 1523680K/49152K bytes of memory.
Processor board ID FTX1529AH4U
3 Gigabit Ethernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
16 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
500472K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2921/K9          XXXXXXXXXXX
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
uc            uck9          Permanent     uck9
data          None          None          None
Show diag:
Slot 0:
        C2921 Mother board 3GE, integrated VPN and 4W Port adapter, 4 ports
        Port adapter is analyzed
        Port adapter insertion time 08:56:41 ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC15224RDW
        Hardware Revision        : 1.0
        Part Number              : 73-11835-06
        Top Assy. Part Number    : 800-30794-03
        Board Revision           : D0
        Deviation Number         : 113332
        Fab Version              : 03
        Product (FRU) Number     : CISCO2921/K9
        Version Identifier       : V03
        CLEI Code                : CMMBL00ARA
        Processor type           : C2
        Chassis Serial Number    : XXXXXXXXXXX
        Chassis MAC Address      : 0007.7de9.5fa0
        MAC Address block size   : 80
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 35 32 32 34 52 44 57 40
          0x10: 06 16 41 01 00 82 49 2E 3B 06 C0 46 03 20 00 78
          0x20: 4A 03 42 44 30 88 00 01 BA B4 02 03 CB 8C 43 49
          0x30: 53 43 4F 32 39 32 31 2F 4B 39 89 56 30 33 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 42 4C 30 30 41 52
          0x50: 41 09 C2 C2 8B 46 54 58 31 35 32 39 41 48 34 55
          0x60: C3 06 00 07 7D E9 5F A0 43 00 50 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 03 40 01 63 FF FF FF FF FF
          0x80: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x90: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xA0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xB0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xC0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Internal Power Supply information
        Top Assy. Part Number    : 341-0226-02
        Deviation Number         : 0
        PCB Serial Number        : DCA1524K2ZM
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Version Identifier       : V02
        Product (FRU) Number     : PWR-2921-51-AC
        CLEI Code                : 0000000000
        Board Revision           : A0
          0x00: 04 FF 40 05 E2 DF 45 01 55 00 E2 02 88 00 00 00
          0x10: 00 C1 8B 44 43 41 31 35 32 34 4B 32 5A 4D 03 00
          0x20: 81 00 00 00 00 04 00 89 56 30 32 20 CB 8E 50 57
          0x30: 52 2D 32 39 32 31 2D 35 31 2D 41 43 C6 8A 30 30
          0x40: 30 30 30 30 30 30 30 30 F3 00 59 41 01 22 42 00
          0x50: 05 F8 00 50 01 F3 18 3B 02 F0 19 D9 03 E8 1B 76
          0x60: 04 E2 1C 49 05 D9 1D 1B 06 D8 1D ED 07 CF 1E BF
          0x70: 08 CE 1F 40 09 C2 1F B8 0A B8 20 34 0B B7 20 B0
          0x80: 0D AF 21 0C 0F 9F 21 67 11 91 21 94 13 87 21 C0
          0x90: 17 6E 21 DB 1B 57 21 EA 1F 3F 21 E2 23 28 21 D4
          0xA0: 27 0A 21 CD 42 41 30 FF FF FF FF FF FF FF FF FF
        PVDM Slot 0:
        64-channel (G.711) Voice/Fax PVDM3 DSP DIMM PVDM daughter card
        Part Number              : 73-11809-03
        Board Revision           : B0
        Fab Version              : 03
        PCB Serial Number        : FOC1525580Q
        RMA History              : 00
        Processor type           : 00
        Product (FRU) Number     : PVDM3-64
        Version Identifier       : V01
          0x00: 04 FF 40 05 DB 41 01 00 82 49 2E 21 03 42 42 30
          0x10: 88 00 00 00 00 02 03 C1 8B 46 4F 43 31 35 32 35
          0x20: 35 38 30 51 03 00 81 00 00 00 00 04 00 09 00 CB
          0x30: 8F 50 56 44 4D 33 2D 36 34 20 20 20 20 20 20 20
          0x40: 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF FF FF
          0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        HWIC CSU/DSU WAN daughter card
        Top Assy. Part Number    : 800-28804-01
        Board Revision           : C0
        Fab Version              : 02
        PCB Serial Number        : FOC144132GM
        RMA History              : 00
        Fab Part Number          : 28-8143-02
        Product (FRU) Number     : HWIC-1DSU-T1
        CLEI Code                : COUIALECAA
          0x00: 04 FF 40 05 8A 41 01 00 C0 46 03 20 00 70 84 01
          0x10: 42 43 30 02 02 88 00 00 00 00 C1 8B 46 4F 43 31
          0x20: 34 34 31 33 32 47 4D 03 00 81 00 00 00 00 04 00
          0x30: 85 1C 1F CF 02 CB 8C 48 57 49 43 2D 31 44 53 55
          0x40: 2D 54 31 89 56 30 31 20 D9 02 40 C1 C6 8A 43 4F
          0x50: 55 49 41 4C 45 43 41 41 FF FF FF FF FF FF FF FF
Slot 1:
        SM-NM-ADPTR
        Port Adapter is analyzed
        Port Adapter insertion time 08:56:41 ago
        PCB Serial Number        : FOC152528RH
        Part Number              : 73-12434-04
        Top Assy. Part Number    : 800-32481-01
        Board Revision           : E0
        Fab Version              : 05
        RMA History              : 00
        Product (FRU) Number     : SM-NM-ADPTR
          0x00: 04 FF C1 8B 46 4F 43 31 35 32 35 32 38 52 48 40
          0x10: 05 F4 41 01 00 82 49 30 92 04 C0 46 03 20 00 7E
          0x20: E1 01 42 45 30 88 00 00 00 00 02 05 03 00 81 00
          0x30: 00 00 00 04 00 CB 8B 53 4D 2D 4E 4D 2D 41 44 50
          0x40: 54 52 89 56 30 31 00 D9 03 40 C1 CB F3 00 03 40
          0x50: 0B E3 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        Voice VM-8FXS/DID  Port adapter
        Port adapter insertion time 08:56:10 ago
        Top Assy. Part Number    : 800-22992-04
        Board Revision           : A0
        Fab Version              : 05
        PCB Serial Number        : FOC15221BT3
        RMA History              : 00
        Product (FRU) Number     : EVM-HD-8FXS/DID
        Version Identifier       : V04
        Longitudinal Calibration : 00 20 20 20 20 20 20 20
                                   20
        CLEI Code                : CNP5130AAD
          0x00: 04 FF 40 04 16 41 01 00 C0 46 03 20 00 59 D0 04
          0x10: 42 41 30 88 00 00 00 00 02 05 C1 8B 46 4F 43 31
          0x20: 35 32 32 31 42 54 33 03 00 81 00 00 00 00 04 00
          0x30: CB 8F 45 56 4D 2D 48 44 2D 38 46 58 53 2F 44 49
          0x40: 44 89 56 30 34 20 D9 02 40 C1 D3 09 00 20 20 20
          0x50: 20 20 20 20 20 C6 8A 43 4E 50 35 31 33 30 41 41
          0x60: 44 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        EM Slot 0:
        EM3-HDA-8FXS/DID Voice Expansion Module (8 port)
        Top Assy. Part Number    : 800-27474-04
        Board Revision           : A0
        Fab Version              : 08
        PCB Serial Number        : FOC15230CJR
        RMA History              : 00
        Product (FRU) Number     : EM3-HDA-8FXS/DID
        CLEI Code                : IPU2ALFDAB
        Longitudinal Calibration : 01 10 10 84 6E 10 10 89
                                   B3 10 10 75 69 10 10 8B
                                   6A 10 10 AA 59 10 10 76
                                   98 10 10 AB 64 10 10 73
                                   69
          0x00: 04 FF 40 05 1C 41 01 00 C0 46 03 20 00 6B 52 04
          0x10: 42 41 30 88 00 00 00 00 02 08 C1 8B 46 4F 43 31
          0x20: 35 32 33 30 43 4A 52 03 00 81 00 00 00 00 04 00
          0x30: CB 90 45 4D 33 2D 48 44 41 2D 38 46 58 53 2F 44
          0x40: 49 44 89 56 30 32 20 D9 02 40 C1 C6 8A 49 50 55
          0x50: 32 41 4C 46 44 41 42 D3 21 01 10 10 84 6E 10 10
          0x60: 89 B3 10 10 75 69 10 10 8B 6A 10 10 AA 59 10 10
          0x70: 76 98 10 10 AB 64 10 10 73 69 FF FF FF FF FF FF
        EM slot 1: None
John Watkins
Level 4
Level 4
Here are the Show call, show voice port info.
show voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
1/0/0           --  fxs-ls      up    up   off-hook idle     y
1/0/1           --  fxs-ls      up    up   off-hook idle     y
1/0/2           --  fxs-ls      up    dorm on-hook  idle     y
1/0/3           --  fxs-ls      up    dorm on-hook  idle     y
1/0/4           --  fxs-ls      up    dorm on-hook  idle     y
1/0/5           --  fxs-ls      up    dorm on-hook  idle     y
1/0/6           --  fxs-ls      up    dorm on-hook  idle     n
1/0/7           --  fxs-ls      up    dorm on-hook  idle     n
1/0/8           --  fxs-ls      up    dorm on-hook  idle     y
1/0/9           --  fxs-ls      up    dorm on-hook  idle     y
1/0/10          --  fxs-ls      up    dorm on-hook  idle     y
1/0/11          --  fxs-ls      up    dorm on-hook  idle     n
1/0/12          --  fxs-ls      up    dorm on-hook  idle     y
1/0/13          --  fxs-ls      up    dorm on-hook  idle     y
1/0/14          --  fxs-ls      up    dorm on-hook  idle     y
1/0/15          --  fxs-ls      up    dorm on-hook  idle     y
PWR FAILOVER PORT        PSTN FAILOVER PORT
show voice call st
CallID     CID  ccVdb      Port        Slot/DSP:Ch  Called #   Codec    MLPP Dial-peers
0x8A9      1F23 0x40860650 1/0/2            0/1:2  *XXXXXXXXX g711ulaw 1/65000
1 active call found
show voice call sum
PORT           CODEC     VAD VTSP STATE            VPM STATE
1/0/0         -          -  -                     FXSLS_PARK
1/0/1         -          -  -                     FXSLS_PARK
1/0/2         g711ulaw   n  S_CONNECT             FXSLS_CONNECT
1/0/3         -          -  -                     FXSLS_ONHOOK
1/0/4         -          -  -                     FXSLS_ONHOOK
1/0/5         -          -  -                     FXSLS_ONHOOK
1/0/6         -          -  -                     FXSLS_ONHOOK
1/0/7         -          -  -                     FXSLS_ONHOOK
1/0/8         -          -  -                     FXSLS_ONHOOK
1/0/9         -          -  -                     FXSLS_ONHOOK
1/0/10        -          -  -                     FXSLS_ONHOOK
1/0/11        -          -  -                     FXSLS_ONHOOK
1/0/12        -          -  -                     FXSLS_ONHOOK
1/0/13        -          -  -                     FXSLS_ONHOOK
1/0/14        -          -  -                     FXSLS_ONHOOK
1/0/15        -          -  -                     FXSLS_ONHOOK
Update:
Cisco TAC replaced the  EVM-HD-8FXS/DID voice module in the router and issue is still occuring, now on other ports as well.. Next an attempt to replace the PVDM at this location.
bmanion
Hi John,
Did you get a resolution to this issue?
We are seeing the EXACT same issue with these EVM cards on mulitple 2911s with PVDM3-64s and 3925s with PVDM3-128s.
Any help would be appreciated!
I ran accross the bug below. Altough we are seeing this on other ports besides first two on the HA and HDA 8/FXS cards. Also we are running different DSPWARE versions than described. Sounds like this may be wider in scope than what Cisco believes.
CSCth64129 Bug Details
FXS Voice port in OFFHOOK State once phone is hungup
Symptom:
FXO Voice Port down once the router is booted
Conditions:
Issue is seen from 15.1(2.7)T with dspware 27.0.201
Workaround:
unknown
15.0M
15.1(2.3)PI14d
15.1(2.7)T
15.1(2.12)T
15.1(0.0.6)PIL15
15.1(0.0.6)PIL15
15.0(1)M3.5
15.0(1)M3.11
15.0(1)XA5
15.1(1)T2.9
15.0(1)M5.9
15.1(2)T2.5
Known Affected Versions
Fixed-In
15.1(2.16)T
15.1(1)T1.7
15.1(2.3.12)PIB15
15.1(2.19.1)PIA15
15.1(1)XB3
15.0(1)M8.12
15.0(1)M9
