I have an CUBAC attendant console (version 8.6) running on a Call Manager 8.5. The primary attendant can log into her console associated to her phone. After hours and at lunch she logs out and another user is supposed to log in. Th...
Hi Guys,For the second time in 2 months we have problem with our publisher. Publisher is reachable via ping and SSH but doesn't working anymore.In console we have the following:WARNING: The /common file system is mounted read only. Please use Recover...
Hi,We have a customer with CUCM 8.5 and CUCXN 8.5, which is using a call handler to deliver some call to a Call center service via SIP Trunk. In detail:a) DN 3500 is CFAll to Unity Voice Mail Pilotb) Unity has a call handler with 3500. Some options o...
I watched a PEC video with everyone's friend Bobbi Martin. During the presentation, she mentioned that the App server cam be loaded on VMware, specifically on ESXi. Has anyone successfully installed this?
Hi, i have controller e1 and i want forward all coming call to another router for example1- i have a router(RU01) and it has a controller e1 in dubai and it cannot run service aa and queue so i decide forward to another router able to run service aa ...
I am trying to get jabber working on Android phones.Call Manager 7.1.5I've got it working for iPhones, I have it working for the Samsung Note 2 running Android 4.1.1But I can't get it working with the Samsung Galaxy 2. I've tried with Jabber versions...
Hello,Just wondering if there is a way to extract Call History from 79XX phones.Thanks,Ayaz
Good day.Is it possible Bulk add some PTs to all CSS?We have about 70 CSS,so do it manual will be crazy a little...I was not able find match menu in Bulk Administration menu.UCM 8.6What you advice?Thanks.
Can SIP phone work? on CME as SRSTSent from Cisco Technical Support Android App
Hello,CUCM 8.x with remote sites and 2800 series routers at each site. Phones register centrally. Is there anyway to get MOH from an audio source that is local to the remote site instead of coming across the WAN? Bandwidth is at...
Hello All,I am working to switch some AT&T analog DID lines from an existing Nortel PBX to a my Cisco 2921 with an H323 setup back to CUCM 8.6. Calls to the old PBX worked fine. After switch to the Cisco setup calls come in with a single digit (only ...
Hello,Haven't messed with the 7905s in forever and I have a firmware question. It currently has a SIP firmware loaded on the phone and I wanted to get this phone working again on SCCP instead. Now on newer phones a firmware reset is easy but these ...
HelloHardwareCisco 2811Flash 128Meg RAM 512MegIOS 124-24.T3 Card : VWIC2-2MFT-T1/E1 2 PVDM cards : PVDM2-32 and PVDM2-16Cisco is configured as a voice gateway I would like to know how many voice call the cisco 2811 can support with the codec G711ulaw...
Hello all.I have a question regarding SIP Trace Analysis,When I am traking a SIP Trace (using Wireshark), is it anyhow possible to understand the INVITE messgae is re-routed or not.I mean ...Some VoIP Software have the function to set multiple Gatewa...
Hello,We have a situation where we have 2 2811 routers configured to receive calls from several sip providers and forward them to a pbx on the LAN by also using SIP.Coded is the same , incoming g729r8 and goes out to the pbx with g729r8 .For example ...
Subject | Author | Posted |
05-08-2025 04:33 AM | ||
05-05-2025 11:16 AM | ||
04-30-2025 05:24 AM | ||
04-30-2025 01:54 AM | ||
04-29-2025 03:01 PM |
User | Count |
5 | |
3 | |
1 | |
1 | |
1 |
