Question regarding ICT between UCM's
Kelly Dodd
Cluster 1
CUCM v6.1.2
1 Pub
2 Sub's
Cluster 2
CUCM v8.5.1
1 Pub
3 Sub's
I have configured an Inter-Cluster Trunk (non-gatekeeper controlled) between the 2 clusters.
Within the Trunk Configuration on 6.1.2, listed in the Remote CUCM Information portion of the config page, there is only Server 1, 2, & 3 (IP address/host name).
Is it possible to have more than 3 entries available for configuration?  That is, I would like to have the option of adding a 4th server entry.  Is this possible?
Jaime Valencia
No, you cannot, as you can see, you can only have 3 destinations per ICT in that version.
You would need to create another ICT with the 4th IP and set it in the RG/RL
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
java
java
Great, thanks for the quick reply.
