2921 router as H.323 gateway will support as SMS gateway
Could please let us know 2921 router as H.323 gateway will support as SMS gateway for sending alter message from ticket application.
Manish Gogna
Hi Balamurugan,
2900 series suupports EHWIC cards as per the following
http://www.cisco.com/c/en/us/products/routers/2900-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
And as per the datasheet and FAQ for the EHWIC , SMS feature is supported
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/data_sheet_c78-659405.html
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/3g-wireless-wan-high-speed-wan-interface-card/prod_qas0900aecd80600f5d.html
" Q. Do the Cisco 3G WWAN EHWICs support SMS?
A. Yes, SMS service, which allows event notification through SMS and SMS-initiated data callback, is supported. Refer to Configuring Cisco EHWIC and 880G for 3.7G (HSPA+)/3.5G (HSPA) and Configuring Cisco EHWIC and 880G for 3G (EV-DO Rev A) for SMS and SMS-initiated data callback related configuration."
Manish
Thanks for the reply Manish, do the VWIC - E1 line supports SMS gateway.
