3905 on CME 9.1?
Dustin Peet
Hello All-
I've read that the 3905 should be supported on CME 8.8 and greater.  I have a system running 9.1 and when I run "load ?" I don't have the option for a 3905....  Am I missing something here?
XXXXXXXX-CME#sh telephony-service
CONFIG (Version=9.1)
Version 9.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
XXXXXXXX-CME(config-telephony)#load ?
  12SP       12SP+ and 30VIP phones
  6901       Cisco IP Phone 6901
  6911       Cisco IP Phone 6911
  6921       Cisco IP Phone 6921
  6941       Cisco IP Phone 6941
  6945       Cisco IP Phone 6945
  6961       Cisco IP Phone 6961
  7902       Cisco IP Phone 7902
  7905       Cisco IP Phone 7905
  7906       Cisco IP Phone 7906
  7910       Cisco IP Phone 7910
  7911       Cisco IP Phone 7911
  7912       Cisco IP Phone 7912
  7914       Cisco IP Phone 7914 14-Button Line Expansion Module
  7915-12    Cisco IP Phone 7915 12-Button Line Expansion Module
  7915-24    Cisco IP Phone 7915 24-Button Line Expansion Module
  7916-12    Cisco IP Phone 7916 12-Button Line Expansion Module
  7916-24    Cisco IP Phone 7916 24-Button Line Expansion Module
  7920       Cisco IP Phone 7920
  7921       Cisco IP Phone 7921
  7925       Cisco IP Phone 7925
  7926       Cisco IP Phone 7926
  7931       Cisco IP Phone 7931
  7935       Cisco IP Conference Station 7935
  7936       Cisco IP Phone 7936
  7937       Cisco IP Conference Station 7937
  7941       Cisco IP Phone 7941
  7941GE     Cisco IP Phone 7941GE
  7942       Cisco IP Phone 7942
  7945       Cisco IP Phone 7945
  7960-7940  Cisco IP Phone 7940/7960
  7961       Cisco IP Phone 7961
  7961GE     Cisco IP Phone 7961GE
  7962       Cisco IP Phone 7962
  7965       Cisco IP Phone 7965
  7970       Cisco IP Phone 7970
  7971       Cisco IP Phone 7971
  7975       Cisco IP Phone 7975
  7985       Cisco IP Phone 7985
  8941       Cisco IP Phone 8941
  8945       Cisco IP Phone 8945
  ata        ATA  phone emulation for analog phone
I also need to figure out how to get firmware for an 8851 on.  I've read something about using "fast track"  Has anyone had success with that?
Thanks!
You can find link below on how upgrade firmware on sip phones using CME :
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/99946-cme-sip-guide.html
Aditya Gupta
Aditya Gupta
Hi Dustin
3905 is configured as a SIP phone, not sccp. You are not going to find this under Telephony Service.
You need "voice register global" to configure this phone
Aditya Gupta
Aditya Gupta
Thanks.  that worked fine.  It's too bad I didn't know that first.  I put all of my DNs as ephone-dn under telephony service and then I had to redo them all as voice register dns.  But overall not that big of a deal, only about 70.
Thanks Aditya
HI
I have the same problem too.But when I use "load " in my SIP register command(voice register global),there is no 8851 and 8865.How can you solve the problem?
router1(config)#voice register global
router1(config-register-global)#load ?
3905 Cisco SIP Phone 3905
3911 Cisco SIP Phone 3911
3951 Cisco SIP Phone 3951
6901 Cisco SIP Phone 6901
6911 Cisco SIP Phone 6911
6921 Cisco SIP Phone 6921
6941 Cisco SIP Phone 6941
6945 Cisco SIP Phone 6945
6961 Cisco SIP Phone 6961
7821 Cisco SIP Phone 7821
7841 Cisco SIP Phone 7841
7861 Cisco SIP Phone 7861
7905 Cisco SIP Phone 7905
7906 Cisco SIP Phone 7906
7911 Cisco SIP Phone 7911
7912 Cisco SIP Phone 7912
7941 Cisco SIP Phone 7941
7941GE Cisco SIP Phone 7941GE
7942 Cisco SIP Phone 7942
7945 Cisco SIP Phone 7945
7960-7940 Telecaster 7960 & 7940 phones
7961 Cisco SIP Phone 7961
7961GE Cisco SIP Phone 7961GE
7962 Cisco SIP Phone 7962
7965 Cisco SIP Phone 7965
7970 Cisco SIP Phone 7970
7971 Cisco SIP Phone 7971
7975 Cisco SIP Phone 7975
8941 Cisco SIP Phone 8941
8945 Cisco SIP Phone 8945
8961 Cisco SIP Phone 8961
9945 Cisco SIP Phone 9945
9951 Cisco SIP Phone 9951
9965 Cisco SIP Phone 9965
9971 Cisco SIP Phone 9971
ATA Cisco SIP Phone ATA
ATA-187 Cisco Analog Phone Adapter ATA 187
Cius Cisco Cius (Android based Tablet)
DX650 Cisco Desktop Collaboration Experience DX650
E20 Cisco Video Phone E20
router1(config-register-global)#load 8851 ?
% Unrecognized command
