09-14-2017 04:16 AM - edited 03-17-2019 11:10 AM
Hi folks,
Am troubleshooting a phone issue and need support / guidance in understanding CUCM SDL Signalling messages.
Eg:
1. Line 5730: 32049045.000 |16:37:00.330 |SdlSig |CcUpdateRegistration |restart0
2. Line 5737: 32049047.000 |16:37:00.330 |SdlSig |CcUpdateRegistration |call_active10
3. Line 5751: 32049055.000 |16:37:00.330 |SdlSig-O |CcUpdateRegistration |NA RemoteSignal
4. Line 19500: 32020989.000 |16:33:33.165 |SdlSig |CcSetupReq |null0
5. Line 19502: 32020990.000 |16:33:33.165 |SdlSig |CcSetupReq |wait
6. 32021179.000 |16:33:34.199 |SdlSig |CcSetupConf |call_received7
Does restart0 means Phone restarted?
Call Active10 means Call is Active
Please suggest.
Thanks & regards,
Ritesh Desai
09-18-2017 12:38 AM
09-19-2017 01:45 AM
Rajan is correct. Your best bet to troubleshoot phone registration is to look at CUCM event viewer logs.
Use RTMT> go to Syslog viewer, select the cucm node that the phone is registred to, thehn click on application logs>alternatesyslog
When a phone un-registers from CUCM it will print a "Lastoutofserviceinformation" alarm. The reason for the out of service will then also be logged
Here are the lists or link to know what each reason code represents
Phone registration reason code
https://supportforums.cisco.com/discussion/11432616/last-out-services-information-cisco-phone
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/err_msgs/8_x/ccmalarms861.html
You can also refer to this link on troubleshooting phone registration:
09-19-2017 02:12 AM - edited 09-19-2017 02:26 AM
Hi Ayodeji,
Thanks for valuable information. I will go through this. I dint knew that I can see from RTMT event viewer. Thanks for steps as well!
thanks & regards,
Ritesh Desai.
