3905 support voice mail or not ?
Aman Soi
Yes,it does.
You can refer the links.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/3905/8_6/english/quick_start_guide/3905quick_921.pdf
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cuipph/3905/10_0/english/user_guide/IP05_BK_U2FC56CE_00_user-guide-3905_10_0/IP05_BK_U2FC56CE_00_user-guide-3905_10_0_chapter_011.html
regds,
aman
Jaime Valencia
VM support is not defined by the endpoint you use, you can always have a VM, at least assuming you're asking about a Cisco option, because you don't mention that.
At the very least, you should mention what VM option you're asking about, don't you think???
java
if this helps, please rate
