3945E IOS Upgrade bootstrap question
I upgraded from c3900e-universalk9-mz.SPA.151-4.M1.bin to c3900e-universalk9-mz.SPA.152-2.T.bin, but the bootstrap is showing: Version 15.1(1r)T2.
Is this OK?
Jonathan Schulenberg
If both images remain on flash the system will boot to the one located 'first' on the filesystem. You can use the 'boot system flash:c3900e-universalk9-mz.SPA.152-2.T.bin' config command to force a boot to the other load.
Alright. Thanks!
Oh, also just to be sure: the bootstrap is separate from the actual IOS image running. A 'show version' will tell you that. Bootstrap is also known as ROMMON and is just there to recover the router.
