3rd party SIP device (gigaset) registration to CME fails
Paul Cobley
I am trying to get some 3rd party devices (gigaset DECT gateway 192.168.0.22) to register to a CME (192.168.0.79) box.
I have 3 x extensions configured on the Gigaset but I am getting SIP errors :-
000226: Sep 23 18:00:36.779: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
000227: Sep 23 18:00:36.779: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
000228: Sep 23 18:00:36.783: //49/E232B6C88021/SIP/Error/ccsip_spi_register_incoming_registration: Error during REGISTER for contact - 192.168.0.22 148
000229: Sep 23 18:00:36.783: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
The important bits of the config :-
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to sip
sip
  bind control source-interface FastEthernet0/0
  bind media source-interface FastEthernet0/0
  registrar server expires max 120 min 60
voice register global
mode cme
source-address 192.168.0.79 port 5060
max-dn 10
max-pool 10
load ATA SIPDefault.cnf
authenticate register
authenticate realm all
tftp-path flash:
create profile sync 0004623540902042
voice register dn  1
number 144
call-forward b2bua noan 100 timeout 20
allow watch
name 144
label 144
voice register dn  2
number 145
allow watch
name 145
label 145
voice register dn  3
number 148
allow watch
name 148
label 148
voice register pool  1
id mac 1111.1111.1111
type ATA
number 1 dn 1
dtmf-relay rtp-nte sip-notify
username 144 password 144
codec g711ulaw
voice register pool  2
id mac 2222.2222.2222
type ATA
number 1 dn 2
username 145 password 145
codec g711ulaw
voice register pool  3
id mac 3333.3333.3333
type ATA
number 1 dn 3
username 148 password 148
codec g711ulaw
Here's a debug ccsip error & ccsip messages :-
000225: Sep 23 18:00:36.775: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
REGISTER sip:192.168.0.79 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.22:5060;branch=z9hG4bK29b5ed11d73d42d113320c018fa2b75;rport
To: "148" <sip:148@192.168.0.79>
Call-ID: 1651868960@192_168_0_22
CSeq: 2 REGISTER
Contact: <sip:148@192.168.0.22:5060>
Authorization: Digest username="148", realm="all", qop=auth, algorithm=MD5, uri="sip:192.168.0.79", nonce="70DD181600048BD9", nc=00000001, cnonce="30b116ca9a5cecaa8077cd07fbb082c1", response="5374b412f7c295ac13bf5b6175869799"
Max-Forwards: 70
User-Agent: N720-DM-PRO/70.040.00.000.000
Expires: 60
Allow: INVITE, ACK, CANCEL, BYE, OPTIONS, INFO, REFER, SUBSCRIBE, NOTIFY
Content-Length: 0
000230: Sep 23 18:00:36.787: //49/E232B6C88021/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "148" <sip:148@192.168.0.79>;tag=2D7678-22D
Date: Mon, 23 Sep 2013 18:00:36 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 2 REGISTER
Content-Length: 0
000231: Sep 23 18:00:36.787: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REFER sip:148@192.168.0.22:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.0.79:5060;branch=z9hG4bKEAA9
To: <sip:148@192.168.0.22>
Call-ID: E238D0F0-23B011E3-8022ADAE-F94440D4@192.168.0.79
CSeq: 101 REFER
Max-Forwards: 70
Contact: <sip:192.168.0.79:5060>
User-Agent: Cisco-SIPGateway/IOS-12.x
Timestamp: 1379959236
Require: norefersub
Refer-To: cid:0297948
Content-ID: <0297948>
Content-Type: application/x-cisco-remotecc-request+xml
Referred-By: <sip:192.168.0.79>
Content-Length: 292
<?xml version="1.0" encoding="UTF-8"?><x-cisco-remotecc-request><statuslineupdatereq><action>notify_display</action><statustext>Max Phones Exceeded</statustext><displaytimeout>10</displaytimeout><linenumber>0</linenumber><priority>1</priority></statuslineupdatereq></x-cisco-remotecc-request>
000232: Sep 23 18:00:36.791: //49/E232B6C88021/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
CSeq: 2 REGISTER
Content-Length: 0
000233: Sep 23 18:00:36.811: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 420 Bad Extension
CSeq: 101 REFER
Unsupported: norefersub
Content-Length: 0
Would appreciate some assistance to get these DECT handsets to register if you can please.
Many thanks
5 Replies 5
Hi.
Can you try to remove "type ATA" from register pool 3?
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
I removed the type ata, recreated profiles, reset the gigaset and still get the same errors :-
000102: Sep 23 19:33:51.807: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.0.22:5060;branch=z9hG4bK8a80a321ff44a7b29b99942e75800145;rport
To: "148" <148>
Call-ID: 3752067865@192_168_0_22
CSeq: 1 REGISTER
Contact: <148>
Max-Forwards: 70
Expires: 60
Content-Length: 0
000103: Sep 23 19:33:51.811: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
000104: Sep 23 19:33:51.811: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
000105: Sep 23 19:33:51.811: //25/E91E515B8012/SIP/Error/ccsip_spi_register_incoming_registration: Registration Authorization failed with authorization header=
000106: Sep 23 19:33:51.811: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
000107: Sep 23 19:33:51.815: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
To: "148" <148>
Date: Mon, 23 Sep 2013 19:33:51 GMT
CSeq: 1 REGISTER
Content-Length: 0
000108: Sep 23 19:33:51.815: //25/E91E515B8012/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 401 Unauthorized
To: "148" <148>;tag=4A9BB0-267E
CSeq: 1 REGISTER
WWW-Authenticate: Digest realm="all",nonce="085726D5000775F8",algorithm=MD5,qop="auth"
Content-Length: 0
000109: Sep 23 19:33:51.839: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 192.168.0.22:5060;branch=z9hG4bKef933dc052dd58816154baef924488af;rport
To: "148" <148>
CSeq: 2 REGISTER
Contact: <148>
Authorization: Digest username="148", realm="all", qop=auth, algorithm=MD5, uri="sip:192.168.0.79", nonce="085726D5000775F8", nc=00000001, cnonce="d73b0e5cb55083abf1e6c04d57978c0d", response="f2b53d227a972ecc5048883a02e7d604"
Max-Forwards: 70
Expires: 60
Content-Length: 0
000110: Sep 23 19:33:51.843: //-1/xxxxxxxxxxxx/SIP/Error/ccsip_reg_search_call_id_table: No entry found in sipCallID Table
000111: Sep 23 19:33:51.843: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_validate_own_ip_addr: ReqLine IP addr does not match with host IP addr
000112: Sep 23 19:33:51.851: //25/E91E515B8012/SIP/Error/ccsip_spi_register_incoming_registration: Error during REGISTER for contact - 192.168.0.22 148
000113: Sep 23 19:33:51.851: //-1/xxxxxxxxxxxx/SIP/Error/sipSPI_ipip_PassthruContentContainerFreeHelper: Null ContentQ - Exit
000114: Sep 23 19:33:51.851: //25/E91E515B8012/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 2 REGISTER
Content-Length: 0
000115: Sep 23 19:33:51.851: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.0.79:5060;branch=z9hG4bK8717
To: <148>
Call-ID: E9246B84-23BD11E3-8013B5F2-6196802@192.168.0.79
CSeq: 101 REFER
Max-Forwards: 70
Contact: <192.168.0.79:5060>
Timestamp: 1379964831
Require: norefersub
Refer-To: cid:0488955
Content-ID: <0488955>
Referred-By: <192.168.0.79>
Content-Length: 292
notify_displayMax Phones Exceeded1001
000116: Sep 23 19:33:51.855: //25/E91E515B8012/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 2 REGISTER
Content-Length: 0
000117: Sep 23 19:33:51.875: //0/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
To: <148>
CSeq: 101 REFER
Content-Length: 0
Best wishes,
Paul
Hi Paul.
Can you please also post a screenshot of gigaset configuration
Carlo
No problem Carlo.
Thanks for looking.
I'm uploading a sh run, and three screenshots from the Gigaset, one of the VoIP provider where we configure the CME details & a couple of pages for the actual handsets.
Hi Paul.
Thank you for attaching those info.
Have you tryed to upgrade to the latest IOS the CME?
Let me know
Carlo
