500 users- CUCM vs Business Edition
iptuser55
Level 6
Level 6
I`m looking at an option for 500 users with VM and Presense in to MS. 500 users will be probably in the future , the install be start small. What are the advantages of  CUCM overall  Bus. Edition
thanks
There are some advantages and disadvantaged for the BE. The telephony features between a CUCM and a CUCMBE are basically the same, but they differ on scalability. Besides, with CUCM BE you can have Unity Connection embedded, but one disadvantage is there is no redundancy available and with CUCM you can set up clusters and CUCM groups and have a separate Unity Connection with HA.
Both CUCM and CUCMBE can be integrated with MS Lync. Please refer to the Release Notes below and check the supported versions:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucimoc/8_5/english/release/cucimocReleaseNote.html#wp222785
For more info you can check both SRNDs below:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/7x/cmbe.html
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/intro.html
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
iptuser55
Level 6
Level 6
Just to add. I understand the max users is 500 which is our requirement - though you can not tell the future growth however how will  MS OCS/ Lync effect it. - Can you have integrate to MS OCS  via CUCIMOC/ Lync ?
Tere.
Thanks for the reply. You mentioned redundancy, I thought the Cmbe option could have SRST- is this true?
You can still have SRST, but you cannot have multiple servers in a cluster like CUCM.
