IP Telephony and Phones
Personalize banner_3
Labels
Hi, I am having a strange problem with the URL Directories. We have a CUCM cluster based on version 8.5.1.10000-26 and a mix of IP Phone like 7940, 7960, 7912, 7970 and 7911.The customer has a centralized corporate directory accessible by a phone ser...
cbrasolin by Level 5
  • 2434 Views
  • 4 replies
Hi All,I am trying to update some phones using Insert Phones All Details option.  The Job scheduler shows "Success" but no changes happen to the phone that I am trying to update. I am using the CSV file that I have exported with All Details. I modifi...
mightyking by Level 11
  • 2188 Views
  • 2 replies
Log Buffer (4096 bytes):egistered with Gatekeeper VoGK27KI-SKO_Shilong.Apr 28 2011 13:33:06.077 CHT: %SYS-5-CONFIG_I: Configured from console by vty0 (172.31.1.2).Apr 29 2011 02:52:10.112 CHT: %CCH323-2-GTWY_REGSTR_FAILED_ALT_GK: Gateway SKO failed a...
suguoqiang by Frequent Visitor
  • 3487 Views
  • 1 replies
Imagine customer has no use for fax services.  No need for bridge conferencing. No PRI termination in the Cisco Cube.Compression on WAN provided by ISP is G.729.UCM 6.1---->Cisco Cube 3945E-------Cisco Edge router----WAN(ISP)Question:In which scenari...
news2010a by Level 7
  • 809 Views
  • 1 replies
Hello buddies;i have some questions related to DSPs1-DSP mandatory if i use analog module, like FXS or FXO? right?2-for Digital modules like T1E1 Multiflex voice card , is DSP mandatory?3-is this module "T1E1 Multiflex" contain a separate DSP itself?...
Hi,Its not a technical question really more of a solution question.We moved a particular site from an Ericsson PBX to CUCM 6.1 a few years back. The operator was not happy to loose some of the functionality they had when moving over. They used the ol...
gbljoba by Level 4
  • 789 Views
  • 1 replies
HII am using mobile connect with extension mobility and noticed if a call was placed to my number and I am not logged into my phone the call comes through to my SNR destination (my mobile) no problemsbut if I then log into the phone the calls is not ...
bowmail by Level 2
  • 899 Views
  • 2 replies
