We've had a call from a user complaining that his 6921 handset (and a number of colleagues) is not locally logging calls correctly. Indeed, looking at the handset's status messages we see lots of the following:
[11:42:45, 02/21/2013] CALLLOG : Insert calllog failed. Erase call log block |
And the console log reveals matching instances of the following:
ffs_WriteBinToFlashDisk : offset(154368)+size(128) > ffs_sz(131072)
FlashEraseBlock(b0740000,b074ffff);
.FlashEraseBlock(b0790000,b07affff);
..-1228235719 - CALLLOG : Insert calllog failed. Erase call log block
12:10:38, 02/19/2013 : CALLLOG : Insert calllog failed. Erase call log block
CALLLOG : CallLog Insert Failed(-5).
Resetting the handset has not had any effect. None of the errors above is turned up by a Google search. Anyone got an bright ideas?
