ā03-16-2022 10:46 PM
I am facing issue with this model , when i setup soft key it will appear to first 3 buttons of 4 button , means last button doesn't show any thing even there are 4 features in my soft key
your response highly appreciated
Solved! Go to Solution.
ā03-17-2022 01:12 AM
Thanks bro
i got what was the issue
that recent is not showing in soft key so when i changed recent it appears , but if if i want recent to show in this model is there any way
ā03-16-2022 10:50 PM
Is it showing nothing or showing two dots. what happens when you press the fourth button.
ā03-17-2022 12:01 AM - edited ā03-17-2022 12:02 AM
in the last button is showing nothing but other soft key button fine , also i created new soft key template with no luck
Thanks bro
