6921 IP Phone softkey
I am facing issue with this model , when i setup soft key it will appear to first 3 buttons of 4 button , means last button doesn't show any thing even there are 4 features in my soft key
your response highly appreciated
Thanks bro
i got what was the issue
that recent is not showing in soft key so when i changed recent it appears , but if if i want recent to show in this model is there any way
Is it showing nothing or showing  two dots. what happens when you press the fourth button.
Response Signature
in the last button  is showing nothing but other soft key button fine , also i created new soft key template with no luck
Thanks bro
