7800 IP phone compatibility
Kevin Breit
Level 4
Level 4
Can someone please confirm and provide documentation about which CM versions the 7800 series is compatible with? According to the data sheet it is compatible with 8.5(1)+. However, devpacks aren't available for 9.1(1). Yet, the release notes for 7800 loads don't specify compatibility information.
16 Replies 16
Hi Gordon,
Gr8.
Can u share the show version active and registered 78xx phone ?
regds,
aman
ankushgoel_1986
Thanks, do you have any idea how many DLU is required for 7800 series phone as i can not find the same through License Unit calculator on CUCM v8.6
