04-17-2014 03:33 PM - edited 03-16-2019 10:30 PM
Do I need to buy licenses (UCL) for a new 7821 and 8831? I have a lot of DLU available in my CUCM 8.6.
Gino
Solved! Go to Solution.
04-18-2014 02:34 AM
Hi Angel,
7821 will consume 2 DLUs and 8831 will consume 3 DLUs. You can check this using the License Unit Calculator located under System -> Licensing.
If you have a lot of spare DLUs, you should be able to add them and register them to CUCM.
hantale
Sree
04-18-2014 02:34 AM
Hi Angel,
hantale
Sree
04-19-2014 07:58 AM
Hi Hantale:
Do you know what the SKU is for ordering new licenses on CUCM 8.6?
As a told you I have many DLU, but I'd like to kow for the future.
Gino
04-19-2014 08:53 AM
Hi Angel,
You can refer the ordering guide and table 2.1
http://www.cisco.com/web/partners/downloads/partner/WWChannels/technology/ipc/downloads/UC_8_6_OG.pdf
The Cisco® IP Phone 7821 requires a Basic User Connect License (UCL) in order to connect to Cisco Unified Communications Manager. The Cisco® IP Phone 7841 and 7861 require an Enhanced User Connect License (UCL) in order to connect to Cisco Unified Communications Manager.
regds,
aman
