09-21-2014 04:58 AM - edited 03-17-2019 12:14 AM
Hello good day
dears please support me
i have 7821 ip phone and its SIP phone and its not working with SRST in branch location . and as ber Cisco Compatibility Information can support from SRST v 8.6 and i'm already upgrade my routers IOS to 15.0 to support SRST 8.6 adn its not working . do you have any idea
Phone 7821
Routers 2801 IOS 15.1
1861 IOS 15.1
880 IOS 15.3
Thanks & Best Regards,
04-02-2016 05:27 AM
Dear Sir,
We have two Sites .example site A and Site B.call manager Bussiness Edition 6000 is placed in site-A and Site-B phones are registered on this BE 6000 through VPN.In Site-B there is a SRST Router for the redundancy
In site-B there is cisco 7975,7962 ,cp 6921 and cp7861 iphones
After finishing the configuration 7675 and 7962 is able to register on srst router after loss the connectivity of BE 6000.but cp 6921 and cp7861 iphones are not registering on srst router.Please help me
Find the configuration of SRST Router. Please let me know what are the changes i should make
Please Please help me
Building configuration...
Current configuration : 4445 bytes
! Last configuration change at 12:17:18 UTC Sat Apr 2 2016
version 15.4
hostname AUH_SRST
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/1
enable password admin
no aaa new-model
ip dhcp excluded-address 192.168.50.129
ip dhcp excluded-address 192.168.50.130
ip dhcp pool VOICE
import all
network 192.168.50.128 255.255.255.128
default-router 192.168.50.130
option 150 ip 10.10.3.251 10.10.3.250
lease 30
ip cef
no ipv6 cef
trunk group AUH_FXO
hunt-scheme round-robin
cts logging verbose
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
registrar server expires max 600 min 60
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice iec syslog
voice register global
mode esrst
timeouts interdigit 3
system message ETA_FallBack
max-dn 20
max-pool 20
voice register pool 1
id network 192.168.50.128 mask 255.255.255.128
no digit collect kpml
dtmf-relay rtp-nte
codec g711ulaw
voice translation-rule 1
rule 1 /[0-9]+/ /9&/
rule 2 /971/ /900971&/
voice translation-profile FROM_ISP
translate calling 1
license udi pid CISCO2921/K9 sn FCZ193661MR
hw-module pvdm 0/0
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
description #MANAGEMENT#
encapsulation dot1Q 10
ip address 192.168.22.5 255.255.255.248
interface GigabitEthernet0/0.60
description #vOICE vLAN#
encapsulation dot1Q 60
ip address 192.168.50.130 255.255.255.128
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.50.130
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.50.129
control-plane
voice-port 0/0/0
trunk-group AUH_FXO
translation-profile incoming FROM_ISP
cptone AE
timeouts call-disconnect 5
timeouts wait-release 5
timing guard-out 1000
connection plar opx 5333
caller-id enable
voice-port 0/0/1
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/2
trunk-group AUH_FXO
cptone AE
caller-id enable
voice-port 0/0/3
trunk-group AUH_FXO
cptone AE
caller-id enable
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 pots
incoming called-number .
dial-peer voice 1000 voip
destination-pattern 5333
session target ipv4:10.10.3.250
voice-class codec 1
dial-peer voice 1001 voip
destination-pattern 53..
voice-class codec 1
sip-ua
gatekeeper
shutdown
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.50.130 port 2000
max-ephones 25
max-dn 50 dual-line
system message primary ETA_MELCO_LOCAL
system message secondary ETA_MELCO_LOCAL
transfer-pattern .T
keepalive 20
call-forward pattern .T
call-forward busy 5333
call-forward noan 5333 timeout 45
time-zone 35
date-format dd-mm-yy
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password admin
login
transport input telnet
scheduler allocate 20000 1000
end
AUH_SRST#
