7821 ip phone call via vpn drops
tony.elrassy
when 7821 ip phones call an extension reachable  via ipsec tunnel, the far end phone rings but the connection goes out when the call is answered.(nothing is heard, the call drops when answered from far end)
7942's and 7962's are not facing any issue.
below some show commands output.
DL-VG#sh version
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.4(3)M2, RELEASE SOFTWARE (fc2)
DL-VG#sh run
voice register dn  19
 number 7150
 name xxx
 label xxx
 mwi
voice register pool  19
 busy-trigger-per-button 2
 id mac F09E.636F.1BCF
 type 7821
 number 1 dn 19
 cor incoming keyring-local default
 presence call-list
 dtmf-relay rtp-nte
 username xxx password xxx
 codec g711ulaw
dial-peer voice 30 voip
 translation-profile outgoing profile1
 destination-pattern *961T
 session target ipv4:172.16.xx.xx
voice translation-profile profile1
 translate called 1
9 Replies 9
Hi Tony,
can you please activate a debug ccsip messages , make a call and post the output?
Carlo
Please rate all helpful posts "The more you help the more you learn"
hello carlo,
below is the debug output
DL-VG#debug ccsip calls
SIP Call statistics tracing is enabled
DL-VG#
381170: Jul 20 11:41:11.837: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 1D7D074C6C7711E79FE4FBB8DE863A96, SetupTime 11:41:01.567 UTC Thu Jul 20 2017, PeerAddress 0, PeerSubAddress ,
DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 11:41:11.837 UTC Thu Jul 20 2017, DisconnectTime 11:41:11.837 UTC Thu Jul 20 2017, CallOrigin 1, ChargedUnits 0, InfoType 2,
TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
381171: Jul 20 11:41:11.837: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:07/20/2017
11:41:01.561,cgn:7178,cdn:0,frs:0,fid:175581,fcid:1D7D074C6C7711E79FE4FBB8DE863A96,legID:A4AB6,bguid:1D7D074C6C7711E79FE4FBB8DE863A96
381172: Jul 20 11:41:11.845: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 1D7D074C6C7711E79FE4FBB8DE863A96, SetupTime 11:40:50.975 UTC Thu Jul 20 2017, PeerAddress 7178, PeerSubAddress ,
DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 11:41:11.845 UTC Thu Jul 20 2
DL-VG#017, DisconnectTime 11:41:11.845 UTC Thu Jul 20 2017, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitPackets 0, TransmitBytes 0, ReceivePackets 0, ReceiveBytes 0
381173: Jul 20 11:41:11.845: %VOIPAAA-5-VOIP_FEAT_HISTORY: FEAT_VSA=fn:TWC,ft:07/20/2017
11:40:50.977,cgn:7178,cdn:*,frs:0,fid:175580,fcid:1D7D074C6C7711E79FE4FBB8DE863A96,legID:A4AB5,bguid:1D7D074C6C7711E79FE4FBB8DE863A96
381174: Jul 20 11:41:11.849: //674485/1D7D074C9FE4/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x15C0B840
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Calling Number : 7178
Called Number : *9610
Source IP Address (Sig ): 172.xx.xx.xx
Destn SIP Req Addr:Port : 172.xx.xx.xx:50203
Destn SIP Resp Addr:Port : 172.xx.xx.xx:50203
Destination Name : 172.xx.xx.xx
381175: Jul 20 11:41:11.849: //674485/1D7D074C9FE4/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711ulaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 172.xx.xx.xx
Source IP Port (Media): 31780
Destn IP Address (Media): 172.xx.xx.xx
Destn IP Port (Media): 24180
Orig Destn IP Address:Port (Media): [ - ]:0
381176: Jul 20 11:41:11.849: //674485/1D7D074C9FE4/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 500
Hello Tony,
please send the output of a debug casio messages  not calls.
Carlo
here are the supported arguments for debug
DL-VG#debug ccsip ?
all   Enable all SIP debugging traces
calls   Enable CCSIP SPI calls debugging trace
dhcp   Enable SIP-DHCP debugging trace
error   Enable SIP error debugging trace
events   Enable SIP events debugging trace
feature   Enable feature level debugging
function   Enable SIP function debugging trace
info   Enable SIP info debugging trace
level   Enable info level
media   Enable SIP media debugging trace
messages   Enable CCSIP SPI messages debugging trace
non-call   Enable Non-Call-Context trace (OPTIONS, SUBSCRIBE etc)
preauth   Enable SIP preauth debugging traces
states   Enable CCSIP SPI states debugging trace
translate   Enable SIP translation debugging trace
transport   Enable SIP transport debugging traces
verbose   Enable verbose mode
which one should i choose?
in the list you can find messages.
That is what I need.
Carlo
I did my best to filter the messages from unwanted calls.
please specify calling and called number you used during test so I can analyze the call
Carlo
hi,
7178 is calling *9610
hello,
any input regarding the above?
