HI: We have a problem with 3 cisco ip phones series 7940, for a reason we dont know they have become useless.. and the message on the screen is UNPROVISIONED, you please tell us how we can fix it. thank you Miguel Morales Quinta Del Mar 619-56...
Hi guys! I have an VG320 with this config on port 0/1/23: voice-port 0/1/23cptone EStimeouts initial 60timeouts interdigit 60timeouts call-disconnect 1timeouts ringing infinitytimeouts wait-release 1timing hookflash-in 50 0caller-id enable Foreign Ex...
Hi, We have ip phones cisco 7911g. All of them work in the sip mode, they have the same provisioning server(Broadsoft) the same provisioning template. All of them have SIP11.8-5-4S firmware version. The issue is that some of them cannot load or acc...
What is the best way to capacity plan for software MTP resources on Cisco Voice Gateways, which also possess DSP resources and Transcoding, Conferencing as well as terminating E1 circuits? I have already scoped the Voice Gateway model limitations, b...
Hi, I am rather new in UCCX world especially in scripting, I have just created a basic script with a Hidden Sub Flow to another script which allows caller to enter their mobile number and then save it in a Document. Now, I want to know how can we d...
Hi,I have a PC, on which I can capture packets from my IP Phone registered to CM 5.1.3.PC and Phone are on seperate VLANS.When I move the same PC to a phone registered with CUCM 7, I cant see the RTP / SCCP packets.I *have* enabled SPAN to PC Port.I ...
Hi,I'm trying to find out how to set an SX10 to automatically reboot daily, or set a maximum call duration timer. Does anyone know if this is possible? Thank you!
Hello All, We need to remove the value in the Name Dialing (CUCM User Page) for about 5000 users in our organization and keep that field empty. Unfortunately the Bulk Administarotion doesn't offer an option to do so. Is there a SQL query that we can ...
WE have a working CME 8.6 system on a 2851 router and we have 5 DID's, 2 toll free inbound only and 3 inbound/outbound for 3 divisions of my company. We use 4 digit dialing for internal calls. Each phone has an appearance for each of the 3 DIDs and...
Hello, I have a Cisco IP Phone 7821 and would like to have it work with Asterisk. Would anyone be able to help me register the phone with Asterisk? Thanks.
Hi all, I have a problem with Cisco Phone 7970. It's stuck in state Programmable buttons blinking green, Headset light is green and mute light is red That's all. Is there a way to fix it ? (I attached phone pic ) Many thanks.
Hello All,Gateway: CISCO2911/K9IOS Version: 15.3(3)M6We have been slowly converting all of our Branch office's inbound POTs lines to VoIP SIP. And with that I've added some new Dial-Peers for routing their Fax line directly from the CUBE in our HQ to...
CUCM CUC 10.5 What I envision: Calls via fxo (2000) to Call Handler (2005) by schedule, in Day rings a line (x2010) on devices. If calls RNA then go to Call Handler (2006) with Caller Input and if nothing done, to voicemail (x2020) (common voicemail...
Hi all, Just looking for some advice for the process of updating the TOMCAT certs on 3 CUCM, 2 UPS and 2 UCCX servers. They are running version 10.5 and I have obtained the certs in PKCS #7 foramt. I m just wondering can I just uploaded or is the...
Just moved from PRI to sip trunk on a 2851 with CME running IOS 12.4(24)T. Inbound and outbound calls are working fine as well as direct calls to a phone that forwards to voicemail. It is only when transferring to a phone and then forwarding to voi...
Subject | Author | Posted |
01-14-2025 10:33 PM | ||
01-08-2025 01:34 AM | ||
01-05-2025 12:44 AM | ||
01-03-2025 09:47 AM | ||
12-30-2024 03:11 PM |
User | Count |
4 | |
2 | |
2 | |
1 | |
1 |
