7821 Phone error on subcribers on two different CM clusters 8.5.1 and 8.6.2
Humza Khan
I have uploaded devicepacks according to their version respectively, phones are registered in cucm working perfectly, but when we trying to go on phone main page from subcriber, it gives following error.
Unmapped Exception /usr/local/cm/db/xml/xml/Phone_7821_SIP_display_instance.xml (No such file or directory)
I checked db replication status, it state is like
Name             State
CM1                    2
CM2                    3
After adding device pack on both clusters publishers, restarted all pubs and subs. But state mismatch.
As well snapshots attached of all above mentioned things.
waiting for swift response.
Humza Khan
2 Accepted Solutions
Hi Humza
You need to upload the same device pack to all the nodes in the cluster. If you have not done the same, please do so...
If you are enabling a new Device Type , reboot of the node is required where you are installing the device pack
Aditya Gupta
Actually a cluster reboot is required for this, not just rebooting the nodes. The documentation on the DevPack explains this.
java
if this helps, please rate
5 Replies 5
Aditya Gupta
Please post the output of show version active from all the servers in any one cluster
Aditya Gupta
Hi Aditya,
Thanks for reply.
Please find attachments.
Is it possible to resolve this by uploading same devicepacks to subscriber as well.
Humza Khan
Hi Humza
Aditya Gupta
java
Cluster wide issue has been resolved, thanks for your support. But i need to know how can we change the CM2 value on 2 in below scenario.
Name             State
CM1                    2
CM2                    3
Still after uploading patch and restarted cucm 2 replication status is same.
Humza Khan
