03-31-2016 03:54 AM - edited 03-17-2019 06:25 AM
I am unable to register 7821 phone to CME.
03-31-2016 03:57 AM
Hi SIva,
Give more details abt the issue you are facing
What is the error message you are getting.
Share the current config
Provide the debugs if you have
We wont be able to help only with this info.
-- Rajan
03-31-2016 04:07 AM
When i debug i am getting below error:
Mar 31 11:00:22.883: TFTP: Looking for SEPF0B2E5773222.cnf.xml.sgn
Mar 31 11:00:23.827: TFTP: Looking for XMLDefault.cnf.xml.sgdebu
Mar 31 11:00:28.395: TFTP: Looking for SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml.sgnconf t
Mar 31 11:00:30.347: TFTP: Looking for sip78xx.10-2-1-12.loadsvoic
03-31-2016 04:17 AM
Hi Siva,
Can you check in flash whether you have this config file (SEPF0B2E5773222.cnf.xml.sgn) is generated ?
"Type 7821" command is there in phone configuration
Rajan
03-31-2016 04:24 AM
voice register pool 1
busy-trigger-per-button 2
id mac F0B2.E577.3222
session-transport tcp
type 7821
number 1 dn 1
dtmf-relay sip-notify
username 611 password 611
codec g711ulaw
I did it but still i am getting the same error.
