ISDN voice gateway
j.huizinga
Level 6
Level 6
I have an ISDN voice gateway and a SIP trunk connecting to another system. I see the following when I enable debug ISDN q931
*Mar 21 10:56:25.290: ISDN BR1 Q931: RX <- SETUP pd = 8  callref = 0x70
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x0181, 'XXXXX'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0xA1, 'XXXXXXX'
                Plan:ISDN, Type:National
        High Layer Compat i = 0x9181
*Mar 21 10:56:25.326: ISDN BR1 Q931: TX -> CALL_PROC pd = 8  callref = 0xF0
        Channel ID i = 0x89
                Exclusive, B1
*Mar 21 10:56:25.486: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
        Progress Ind i = 0x8181 - Call not end-to-end ISDN, may have in-band info
*Mar 21 10:56:25.510: ISDN BR1 Q931: TX -> ALERTING pd = 8  callref = 0xF0
*Mar 21 10:56:25.534: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
*Mar 21 10:56:25.558: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
*Mar 21 10:56:25.578: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
*Mar 21 10:56:25.602: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
*Mar 21 10:56:25.626: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
*Mar 21 10:56:25.650: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
*Mar 21 10:56:25.846: ISDN BR1 Q931: TX -> PROGRESS pd = 8  callref = 0xF0
The IOS gateway is sending many PROGRESS 8 values, but in another site from this customer with similar configuration, the gateway doesn't send so many PROGRESS  messages.
Any idea?
JH
6 Replies 6
Amit23
Level 4
Level 4
pls share full configuration to see the issue
Warm Regard's
Amit Sahrma
Dennis Mink
What is the issue you are suffering because of this?
Please remember to rate useful posts, by clicking on the stars below.
Amit Sharawat
This is due to the following:
This IOS is detecting that the calling number is not in ISDN format or not detecting this as a known number.
Hello Amit,
This customer will have around 40 remote sites, and we have now installed half of them. All configurations and hardware are similar. I shall connect to some other remote sites, and check the ISDN debug. Although I am sure I didn't see so many PROGRESS messages on other sites, but I don't know what I saw as type plan
Thank you for your help
Jan
Probably, you can test it by correcting the Type and the Calling party number to some number, rather "XXXX" for eg. the message :
Calling Party Number i = 0x0181, '8232001'
                Plan:ISDN, Type:Local
~Amit
This gateway connects with a SIP trunk to another device. This device sends multiple SIP session messages, and the Cisco gateway sends a PROGRESS for each of this message
So issue with SIP, there is not a problem, it works, just a little weird to see so many messages.
Thanks for the responses
JH
