7821 phones registered in data vlan without dhcp option 150
phones 7821,7841 when connected in ports in Data Vlan still able to register with the cucm ver 11.5 ip 172.16.50.3 .data vlan DHCP is on with Network id 172.16.10.0/24 ,no option 150 configured and routing between vlans is enabled.why phones registered and how to prevent the registration when  data vlan? attached console log of phones
1308 INF Feb 27 15:02:01.137921 (452:459) rlogcoll-rlogcoll_setLogProfile() over
1309 NOT Feb 27 15:02:01.138806 (349:381) CDP-cdpSetSwportCfgRemote: Value Sent to IOCTL LOCAL[0] 1 1
1310 NOT Feb 27 15:02:01.142316 (318:318) PAE: -paeNetsdRcvMsg(318): LINK change: status: 0x0 : Network is down
1311 NOT Feb 27 15:02:01.143781 (538:585) JAVA-Calling handleNetSDEvent
1312 NOT Feb 27 15:02:01.146467 (538:898) JAVA-configmgr MQThread|cip.cfg.TimeDateProperty:? - setTimeZone tz:Africa/Cairo ctz:Africa/Cairo
1313 NOT Feb 27 15:02:01.145826 (349:381) CDP-cdpSetPcportCfgRemote 7
1314 NOT Feb 27 15:02:01.161422 (538:898) JAVA-configmgr MQThread|cip.cfg.SipConfig:? - customerUUID is
1315 NOT Feb 27 15:02:01.162063 (538:898) JAVA-configmgr MQThread|cip.cfg.SipConfig: - Entering setProtocolConfigProperties() at 1582808521161 millisecs....<RemoveItLater>
1316 NOT Feb 27 15:02:01.211902 (349:381) CDP-cprSetPortCfg port:1:1 ret:0
1317 NOT Feb 27 15:02:01.219746 (349:381) CDP-cdpSetPcportCfgRemote Value Sent to IOCTL LOCAL[0] 1 1
1318 NOT Feb 27 15:02:01.327971 (538:898) JAVA-configmgr MQThread|cip.cfg.SipConfig:? - embrace feature hack, update line 1, featureId = 9, name = 4015
1319 NOT Feb 27 15:02:01.338074 (336:358) vieo-TCPIF PCPORT Link Change, but no status change
1320 NOT Feb 27 15:02:01.365634 (538:898) JAVA-configmgr MQThread|cip.cfg.SipConfig: - Exiting setProtocolConfigProperties() at 1582808521365 millisecs....<RemoveItLater>
1321 NOT Feb 27 15:02:01.434304 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - CUCM in config file: #0 XmlCallAgentObject: IPv4-name=[172.16.50.3] IPv6-name=[] ethernetPhonePort=2000 sipPort=5060 securedSipPort=5061 priority=0
1322 NOT Feb 27 15:02:01.447276 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - CUCM in config file: #1 XmlCallAgentObject: IPv4-name=[] IPv6-name=[] ethernetPhonePort=0 sipPort=0 securedSipPort=0 priority=32767
1323 NOT Feb 27 15:02:01.448802 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - CUCM in config file: #2 XmlCallAgentObject: IPv4-name=[] IPv6-name=[] ethernetPhonePort=0 sipPort=0 securedSipPort=0 priority=32767
1324 NOT Feb 27 15:02:01.450907 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - CUCM in config file: #3 XmlCallAgentObject: IPv4-name=[] IPv6-name=[] ethernetPhonePort=0 sipPort=0 securedSipPort=0 priority=32767
1325 NOT Feb 27 15:02:01.452372 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - CUCM in config file: #4 XmlCallAgentObject: IPv4-name=[] IPv6-name=[] ethernetPhonePort=0 sipPort=0 securedSipPort=0 priority=32767
1326 NOT Feb 27 15:02:01.568228 (336:358) vieo-TCPIF PCPORT Link Change, but no status change
1327 WRN Feb 27 15:02:01.622798 (314:1610) SECUREAPP-SEC_CAPF_N_IN_USE: CAPF not in use, user cancel ignored
1328 NOT Feb 27 15:02:01.673340 (538:898) JAVA-configmgr MQThread|cip.sec.CapfProperty:? - CapfProp 96
1329 NOT Feb 27 15:02:01.677887 (318:318) PAE: -paeNetsdRcvMsg(318): LINK change: status: 0x0 : Network is down
1330 ERR Feb 27 15:02:01.827712 (538:898) JAVA-configmgr MQThread|cip.cfg.SipConfig:? - processConfigNoError: no config file in RAM, not to store to flash
1331 NOT Feb 27 15:02:01.828994 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - [processConfigObject] result:0,isConfigFromFlash:true
1332 NOT Feb 27 15:02:01.829665 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - Sending update notice to Metmand
1333 NOT Feb 27 15:02:01.834426 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - Sending update notice to Metmand - COMPLETE
1334 NOT Feb 27 15:02:01.835495 (538:898) JAVA-configmgr MQThread|cip.sipcc.SipCcAdapter$CcMgmtListener: - mgmtState=MGMT_INITIALIZING(1)
1335 ERR Feb 27 15:02:01.857347 (532:532) metmand-getMetricReportString INVALID metric report type requested
1336 NOT Feb 27 15:02:01.910300 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - [SipConfig] register() => ipmode: 0(IPv4 Only), ipv4-stack-state: 1(DHCP BOUND), ipv6-stack-state: 199(IPV6 STACK TURNED OFF), ipv4@: 172.16.10.37, ipv6@: ::, ipaddress-valid?true
1337 NOT Feb 27 15:02:01.911307 (538:898) JAVA-configmgr MQThread|cip.cfg.Config: - [SipConfig] commiting CM_CHANGED property, current value:false
1338 NOT Feb 27 15:02:01.912467 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - propertyChanged(): device.settings.config.callmanager.changed
1339 NOT Feb 27 15:02:01.915214 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - [addCcmsToCAgentList] [0] ipmode: IPv4 Only, cmIPv4Name:"172.16.50.3", cmIPv6Name:"", cmIPv4@: , cmIPv6@: , cmPort: 5060, cmSecurePort: 5061
1340 NOT Feb 27 15:02:01.968808 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - cm.namev4="172.16.50.3",cm.namev6="",cm.ipv4=,cm.ipv6=,port=5060,is.valid=true,security-level=0
1341 NOT Feb 27 15:02:01.970090 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - [addCcmsToCAgentList] [1] ipmode: IPv4 Only, cmIPv4Name:"", cmIPv6Name:"", cmIPv4@: , cmIPv6@: , cmPort: 0, cmSecurePort: 0
1342 NOT Feb 27 15:02:01.970914 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - [addCcmsToCAgentList] [2] ipmode: IPv4 Only, cmIPv4Name:"", cmIPv6Name:"", cmIPv4@: , cmIPv6@: , cmPort: 0, cmSecurePort: 0
1343 NOT Feb 27 15:02:01.971524 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - [addTftpToCAgentList] tftpv4: , tftpv6: ::, secure-mode: Non Secure, ipmode:IPv4 Only
1344 NOT Feb 27 15:02:01.975034 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter$CcMgmtListener: - cfgDlndDone(): mgmt_state=1config-fetch-requested?true
1345 NOT Feb 27 15:02:01.976224 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - downloadADRFile(): bluetooth not supported.
1346 NOT Feb 27 15:02:01.979490 (302:302) downd-DDFORK - execing [/usr/sbin/dgetfile][-L620][ ]
1347 NOT Feb 27 15:02:01.982389 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - propertyChanged(): device.settings.config.callmanager.changed
1348 NOT Feb 27 15:02:02.340790 (1616:1616) dgetfile-GETXXTP [GT1616][src=SK72f64050-7ad5-4b47-9bfa-5e9ad9cd4aa9.xml][dest=/tmp/cache/SK-727818856][serv=][serv6=][sec=2]
1349 NOT Feb 27 15:02:02.343873 (1616:1616) dgetfile-In normal mode, call - > makeXXTPrequest (V6...)
1350 NOT Feb 27 15:02:02.347199 (1616:1616) dgetfile-EMCC mode is false
1351 NOT Feb 27 15:02:02.411536 (1616:1616) dgetfile-parseDhcpInfoIntoTftpList(): no valid load server
1352 WRN Feb 27 15:02:02.411750 (1616:1616) dgetfile-XXTP wired servers not configured - file not requested
1353 NOT Feb 27 15:02:02.523332 (1616:1616) dgetfile-DDGETTFTP.RESULT [_17_ Don't have a server
1354 NOT Feb 27 15:02:02.533648 (302:302) downd-SOCKET accept errno=4 "Interrupted system call"
1355 NOT Feb 27 15:02:02.537646 (538:585) JAVA-Thread-0|cip.setg.IpStacksStateProperty:? - IpStacksStateProperty changed from "IPv4-stack-state:1 (DHCP BOUND), IPv6-stack-state:199 (IPV6 STACK TURNED OFF)" to "IPv4-stack-state:1 (DHCP BOUND), IPv6-stack-state:199 (IPV6 STACK TURNED OFF)"
1356 NOT Feb 27 15:02:02.538501 (538:585) JAVA-Calling handleNetSDEvent
1357 NOT Feb 27 15:02:02.836136 (538:898) JAVA-configmgr MQThread|ConfigManager:? - --->ConfigManager PropertyChanged: device.config.io.dscp.config
1358 ERR Feb 27 15:02:02.843369 (538:889) JAVA-System P7-display MQThread|cip.sipcc.FeatureKeyHandler: - Error in downloading softkey file errorCode=16
1359 NOT Feb 27 15:02:02.845231 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - skDnldDone():mgmtState=MGMT_INITIALIZING(1)nativeInit=true,configFileTftpTimeout:false
1360 WRN Feb 27 15:02:02.846635 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - waitingForConfigFile: configFileRequestPending=true, configFileAvailableInRam = false
1361 WRN Feb 27 15:02:02.847489 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - waitingForConfigFile: looking for file=/usr/local/flash0/sip-SEP005F869051F9.cnf.xml
1362 WRN Feb 27 15:02:02.848435 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - waitingForConfigFile: notify sipcc using config-file in flash
1363 NOT Feb 27 15:02:02.849381 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - generateConfigFetchResponse called...configFileAvailable=false configFileRequestPending=true
1364 NOT Feb 27 15:02:02.852037 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - generateConfigFetchResponse: looking for file=/usr/local/flash0/sip-SEP005F869051F9.cnf.xml
1365 NOT Feb 27 15:02:02.852830 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - generateConfigFetchResponse: configFilename= /usr/local/flash0/sip-SEP005F869051F9.cnf.xml
1366 NOT Feb 27 15:02:02.854570 (538:898) JAVA-configmgr MQThread|ConfigManager:? - <---ConfigManager PropertyChanged: device.config.io.dscp.config
1367 NOT Feb 27 15:02:02.855608 (538:889) JAVA-System P7-display MQThread|cip.cfg.SipConfig:? - syncHFUOnOffInfoToSIP, supportBtHFP: false user_enabled_bt:false, admin_enabled_bt:false, user_enabled_hfu:true, admin_enabled_hfu:true
1368 NOT Feb 27 15:02:02.856401 (538:889) JAVA-SIPCC-CC_API: CCAPI_Device_UserEnableHFU: user enabled hfu: 0
1369 NOT Feb 27 15:02:02.876789 (538:585) JAVA-Thread-0|cip.setg.IpStacksStateProperty:? - IpStacksStateProperty changed from "IPv4-stack-state:1 (DHCP BOUND), IPv6-stack-state:199 (IPV6 STACK TURNED OFF)" to "IPv4-stack-state:1 (DHCP BOUND), IPv6-stack-state:199 (IPV6 STACK TURNED OFF)"
1370 NOT Feb 27 15:02:02.889943 (538:889) JAVA-SIPCC-CC_API: CCAPI_Config_response: from_memory:0, received new cfg file sz:45, previous cfg file sz:0, current g_cfg_p buf sz:257
1371 NOT Feb 27 15:02:02.890187 (538:889) JAVA-SIPCC-CC_API: CCAPI_Config_response: Phone not registered. do parse and register.
1372 NOT Feb 27 15:02:02.892263 (538:889) JAVA-CFG : config_parser_main : Starting config file parse.
1373 ERR Feb 27 15:02:02.892659 (538:889) JAVA-CFG : config_set_value : natAddress size error entry size=48, len=4
1374 NOT Feb 27 15:02:02.893544 (538:889) JAVA-SIPCC-CC_API: preConfigParse: HFU feature disabled.
1375 NOT Feb 27 15:02:02.918022 (302:302) downd-DDFORK - execing [/usr/sbin/dgetserver][-L60][ ]
1376 NOT Feb 27 15:02:03.026430 (1638:1638) dgetserver-parseDhcpInfoIntoTftpList(): no valid load server
1377 NOT Feb 27 15:02:03.027346 (1638:1638) dgetserver-GETSRVR [ip=] resolved.
1378 NOT Feb 27 15:02:03.028750 (302:302) downd-DDFORK - execing [/usr/sbin/dgetserver][-L60][ ]
1379 NOT Feb 27 15:02:03.140607 (1638:1638) dgetserver-dgetserver.RESULT [_0_ [PASS] No error
1380 NOT Feb 27 15:02:03.153578 (302:302) downd-SOCKET accept errno=4 "Interrupted system call"
1381 NOT Feb 27 15:02:03.175614 (1644:1644) dgetserver-parseDhcpInfoIntoTftpList(): no valid load server
1382 NOT Feb 27 15:02:03.176438 (1644:1644) dgetserver-GETSRVR [ip=] resolved.
1383 ERR Feb 27 15:02:03.177506 (538:889) JAVA-CFG : config_process_ccm_properties : No valid IPv4 TFTP server configured
1384 NOT Feb 27 15:02:03.178086 (538:889) JAVA-ccm0=172.16.50.3 ccm1= ccm2= sip_port_0=5060 sip_port_1=5060 sip_port_2=5060 length=0
1385 NOT Feb 27 15:02:03.178238 (538:889) JAVA-ccm0=172.16.50.3 ccm1= ccm2= sec_sip_port_0=5061 sec_sip_port_1=5061 sec_sip_port_2=5061 length=0
1386 NOT Feb 27 15:02:03.179063 (538:889) JAVA-ccm0_v6= ccm1_v6= ccm2_v6= lenght=0
1387 NOT Feb 27 15:02:03.179185 (538:889) JAVA-device ip_mode is IPv4
1388 NOT Feb 27 15:02:03.180741 (538:889) JAVA-config_process_ccm_properties: is in Edge mode = FALSE
1389 NOT Feb 27 15:02:03.185899 (538:889) JAVA-CFG : config_set_srst_properties : SRST is not configured.
1390 NOT Feb 27 15:02:03.189043 (538:889) JAVA-CFG : update_sipline_properties : lineMode:0
1391 NOT Feb 27 15:02:03.189500 (538:889) JAVA-CFG : update_sipline_properties : HFU feature is disabled.
1392 NOT Feb 27 15:02:03.193224 (538:889) JAVA-CFG : config_parse_element : versionStamp new=1572178795-d0d420a2-3c7e-47b3-902b-a84aeff8b1cd old=
1393 NOT Feb 27 15:02:03.198718 (538:889) JAVA-CFG : compare_or_set_multi_level_config_value : compare_or_set: CONFIG_PARSER_APPLY
1394 NOT Feb 27 15:02:03.199206 (538:889) JAVA-CFG : config_parser_main : Release memory for xml doc.
1395 ERR Feb 27 15:02:03.201831 (538:889) JAVA-CFG : config_set_string : Parse function failed. ID: 104 myIpv6Addr:
1396 NOT Feb 27 15:02:03.207172 (538:889) JAVA-CFG : postConfigParse : Set CFG: dev_name:SEP005F869051F9 signaling_ip:172.16.10.37 signaling_ipv6: media_ip:172.16.10.37
1397 NOT Feb 27 15:02:03.207660 (538:889) JAVA-CFG : postConfigParse : old CFG: timer_register_expires:0, timer_invite_expires:0, timer_t1:0, voip_control_port:0
1398 NOT Feb 27 15:02:03.208179 (538:889) JAVA-CFG : postConfigParse : Set CFG: dev_name:SEP005F869051F9 signaling_ip:172.16.10.37 media_ip:172.16.10.37
1399 NOT Feb 27 15:02:03.209430 (538:889) JAVA-MED : cc_media_update_video_cap : updating device video capability from [1] to [0]
1400 NOT Feb 27 15:02:03.210834 (538:889) JAVA-MED : updatePresentationCapTblValues : enter...
1401 NOT Feb 27 15:02:03.211262 (538:889) JAVA-MED : updatePresentationCapTblValues : orig gcap[1,0,0,0]
1402 NOT Feb 27 15:02:03.211719 (538:889) JAVA-MED : updatePresentationCapTblValues : new gcap[1,0,0,0]
1403 NOT Feb 27 15:02:03.212177 (538:889) JAVA-MED : updateFeccCapTblValues : enter...
1404 NOT Feb 27 15:02:03.212635 (538:889) JAVA-MED : updateFeccCapTblValues : orig gcap[0]
1405 NOT Feb 27 15:02:03.213093 (538:889) JAVA-MED : updateFeccCapTblValues : new gcap[0]
1406 NOT Feb 27 15:02:03.213612 (538:889) JAVA-MED : updateVidCapTbl : video capability disabled
1407 NOT Feb 27 15:02:03.214802 (336:358) vieo-TCPIF stopVieoServer
1408 NOT Feb 27 15:02:03.220265 (538:915) JAVA-SIPCC-SIP_EVT: SIPTaskProcessListEvent: !!!sip_taskInited is false. So not executing cmd=0x55
1409 NOT Feb 27 15:02:03.224752 (538:889) JAVA-CFG : config_parser_main : Completed config file parse. rtn_result:[2]
1410 NOT Feb 27 15:02:03.227193 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : CONFIG_CHANGED
1411 NOT Feb 27 15:02:03.228322 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - ccReady called...mgmtState=MGMT_INITIALIZING(1), deviceEvent:0, nativeSideInitialized:true
1412 NOT Feb 27 15:02:03.229391 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - ccReady: oldccMode=-1 newccMode=0
1413 NOT Feb 27 15:02:03.231954 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - initializeLinePlane called...
1414 NOT Feb 27 15:02:03.240439 (538:889) JAVA-SIPCC-CC_API: CCAPI_Config_response: send event EV_CC_CONFIG_RECEIVED successfully
1415 NOT Feb 27 15:02:03.243277 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener: - initializeLinePlane(): Mgmt Interface is in Service now..
1416 NOT Feb 27 15:02:03.284083 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - calling initializeLines...
1417 NOT Feb 27 15:02:03.284541 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - initializeLines called...
1418 NOT Feb 27 15:02:03.285273 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - returned from InfogetLines...
1419 NOT Feb 27 15:02:03.285640 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - entering line loop...
1420 NOT Feb 27 15:02:03.286128 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - instidx=0 inst=1 calling getLineInfo.....
1421 NOT Feb 27 15:02:03.393224 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - skDnldDone(): SIPCC waiting on config file
1422 NOT Feb 27 15:02:03.393743 (538:889) JAVA-System P7-display MQThread|cip.sipcc.SipCcAdapter: - UpdateMgmtState [MGMT_INITIALIZING(1)] --> [MGMT_AWAITING_CFG_SYNC(8)]
1423 NOT Feb 27 15:02:03.396520 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - initializeLine called: ref=40126184 lineFeature=9 button=1
1424 NOT Feb 27 15:02:03.490492 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - returned from InfogetFeatures...
1425 WRN Feb 27 15:02:03.492904 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - features is empty...
1426 NOT Feb 27 15:02:03.496230 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter: - UpdateMgmtState [MGMT_AWAITING_CFG_SYNC(8)] --> [MGMT_REGISTERING(4)]
1427 NOT Feb 27 15:02:03.497329 (538:914) JAVA-SIPCC-SIP_DEVICE_MGR: registration_processEvent: Event EV_CC_CONFIG_RECEIVED, current State MGMT_STATE_CREATED
1428 NOT Feb 27 15:02:03.497512 (538:914) JAVA-SIPCC-SIP_DEVICE_MGR: setState: new registration state = MGMT_STATE_REGISTERING
1429 NOT Feb 27 15:02:03.497817 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : STATE
1430 NOT Feb 27 15:02:03.499191 (538:914) JAVA-SIPCC-SIP_DEVICE_MGR: action: cmd: CMD_INSERVICE cfg: signaling_ip=[v4:172.16.10.37,v6:] media_ip=172.16.10.37 pending: signaling_ip=[v4:172.16.10.37,v6:] media_ip=172.16.10.37
1431 NOT Feb 27 15:02:03.499374 (538:914) JAVA-SIPCC-SIP_DEVICE_MGR: action: Setting New Signaling IP [v4:172.16.10.37,v6:], New Media IP 172.16.10.37
1432 ERR Feb 27 15:02:03.499496 (538:914) JAVA-CFG : config_set_string : Parse function failed. ID: 104 myIpv6Addr:
1433 NOT Feb 27 15:02:03.512498 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=VISITING_CCM=0.
1434 NOT Feb 27 15:02:03.513688 (538:915) JAVA-SIPCC-SIP_TRANS: sip_transport_init_ti_addr: Entered
1435 NOT Feb 27 15:02:03.514359 (538:915) JAVA-SIPCC-SIP_TRANS: sip_transport_init_ti_addr: Entered
1436 NOT Feb 27 15:02:03.514512 (538:915) JAVA-SIPCC-SIP_TRANS: sip_transport_init_ti_addr: Unexpected value specified for ip_type : 0
1437 NOT Feb 27 15:02:03.515794 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=SECONDARY_CCM=2.
1438 NOT Feb 27 15:02:03.516954 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=TERTIARY_CCM=3.
1439 NOT Feb 27 15:02:03.517900 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=SRST_CCM=4.
1440 NOT Feb 27 15:02:03.521410 (538:915) JAVA-sip_tcp_init_conn_table() called
1441 NOT Feb 27 15:02:03.521684 (538:915) JAVA-SIP : sip_tcp_get_free_conn_entry : returned index=0
1442 NOT Feb 27 15:02:03.525255 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : SERVER_TRANSPORT
1443 NOT Feb 27 15:02:03.525896 (538:915) JAVA-set_active_ccm: ccm=PRIMARY_CCM port=49987
1444 NOT Feb 27 15:02:03.526415 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=SECONDARY_CCM=2.
1445 NOT Feb 27 15:02:03.526537 (538:915) JAVA-SIPCC-SIP_CC_CONN: sip_transport_setup_cc_conn: <SECONDARY_CCM>: CC address/port not configured2.
1446 NOT Feb 27 15:02:03.527239 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=TERTIARY_CCM=3.
1447 NOT Feb 27 15:02:03.527361 (538:915) JAVA-SIPCC-SIP_CC_CONN: sip_transport_setup_cc_conn: <TERTIARY_CCM>: CC address/port not configured2.
1448 NOT Feb 27 15:02:03.527941 (538:915) JAVA-SIP : sip_transport_init_ti_addrs : Admin has not configured a valid cucm for cucm index=SRST_CCM=4.
1449 NOT Feb 27 15:02:03.528063 (538:915) JAVA-SIPCC-SIP_CC_CONN: sip_transport_setup_cc_conn: <SRST_CCM>: CC address/port not configured2.
1450 NOT Feb 27 15:02:03.528948 (538:915) JAVA-SIPCC-SIP_CC_CONN: sip_regmgr_setup_cc_conns: NO VALID STANDBY CALL CONTROL AVAILABLE!
1451 NOT Feb 27 15:02:03.530535 (538:915) JAVA-SIPCC-SIP_REG: sip_sm_init: Disabling mass reg state
1452 WRN Feb 27 15:02:03.949946 (538:894) JAVA-callagent MQThread|DisplayTask:? - Line 1 property added with dn 4015
1453 NOT Feb 27 15:02:03.961757 (322:392) EWCLIENT-ewclWriteData: Cannot update secret
1454 NOT Feb 27 15:02:04.115550 (538:915) JAVA-SIPCC-SIP_REG: ccsip_register_all_lines: Disabling mass reg state
1455 NOT Feb 27 15:02:04.117228 (538:915) JAVA-SIPCC-UI_API: ui_update_registration_state_all_lines: ***********ALL LINES UN-REGISTERED****************
1456 NOT Feb 27 15:02:04.118876 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener: - lineNotify():mgmtState=MGMT_REGISTERING(4) line=1 registered=false inService=true regRequired = true
1457 NOT Feb 27 15:02:04.121318 (538:915) JAVA-MED : updatePresentationCapTblValues : enter...
1458 NOT Feb 27 15:02:04.121471 (538:915) JAVA-MED : updatePresentationCapTblValues : orig gcap[1,0,0,0]
1459 NOT Feb 27 15:02:04.121562 (538:915) JAVA-MED : updatePresentationCapTblValues : new gcap[1,0,0,0]
1460 NOT Feb 27 15:02:04.121684 (538:915) JAVA-MED : updateFeccCapTblValues : enter...
1461 NOT Feb 27 15:02:04.121776 (538:915) JAVA-MED : updateFeccCapTblValues : orig gcap[0]
1462 NOT Feb 27 15:02:04.121867 (538:915) JAVA-MED : updateFeccCapTblValues : new gcap[0]
1463 NOT Feb 27 15:02:04.121989 (538:915) JAVA-SIP : SIPTaskProcessListEvent : sip_taskInited is set to true
1464 NOT Feb 27 15:02:04.140119 (538:915) JAVA-SIPCC-SIP_MSG_SEND: ccsip_dump_send_msg_info: <172.16.50.3:5060>:REFER s: <sip:172.16.50.3> :1000 REFER::005f8690-51f90002-5595771d-3248496c@172.16.10.37
1465 NOT Feb 27 15:02:04.151411 (538:915) JAVA-SIPCC-SIP_MSG_SEND: ccsip_dump_send_msg_info: <172.16.50.3:5060>:REFER s: <sip:172.16.50.3> :1000 REFER::005f8690-51f90003-3b1d33e0-736f701b@172.16.10.37
1466 NOT Feb 27 15:02:04.161819 (538:915) JAVA-SIPCC-SIP_MSG_SEND: ccsip_dump_send_msg_info: <172.16.50.3:5060>:REFER s: <sip:172.16.50.3> :1000 REFER::005f8690-51f90004-0b47a177-200a5902@172.16.10.37
1467 NOT Feb 27 15:02:04.171982 (538:915) JAVA-ccsip_messaging: sipSPIAddContactHeader: CFGID_DEVICE_NAME = SEP005F869051F9
1468 NOT Feb 27 15:02:04.172226 (538:915) JAVA-ccsip_messaging: sipSPIAddContactHeader: ccb->call_mode = 0, display_name = 4015
1469 NOT Feb 27 15:02:04.201037 (538:915) JAVA-SIPCC-SIP_REG: addDefaultOptionInd: support bfcp 1
1470 NOT Feb 27 15:02:04.201281 (538:915) JAVA-SIPCC-SIP_REG: addDefaultOptionInd: frame_rcc_options_ind_msg: check mobility refresh 0
1471 NOT Feb 27 15:02:04.201403 (538:915) JAVA-SIPCC-SIP_REG: addDefaultOptionInd: support flex_dscp=0
1472 NOT Feb 27 15:02:04.208423 (538:915) JAVA-SIPCC-SIP_REG: xmlEncodeEventData: returned content after encoding:
<?xml version="1.0" encoding="UTF-8"?>
<x-cisco-remotecc-request>
<optionsind>
<combine max="6">
<remotecc>
<status></status>
</remotecc>
<service-control></service-control>
</combine>
<dialog usage="hook status">
<unot></unot>
<sub></sub>
</dialog>
<dialog usage="shared line">
<unot></unot>
<sub></sub>
</dialog>
<presence usage="blf speed dial">
<unot></unot>
<sub></sub>
</presence>
<joinreq></joinreq>
<cfwdall-anyline></cfwdall-anyline>
<coaching></coaching>
<oosalarm></oosalarm>
<rpid-orig-called></rpid-orig-called>
<bfcp></bfcp>
<ix></ix>
<gatewayrecording></gatewayrecording>
<conferenceDisplayInstance></conferenceDisplayInstance>
</optionsind>
</x-cisco-remotecc-request>
1473 NOT Feb 27 15:02:04.216389 (538:915) JAVA-SIPCC-SIP_MSG_RECV: ccsip_dump_recv_msg_info: <172.16.50.3:0 >:202 Acc: "Na2b R2es far3 elnozom" <sip:4015@172.16.10.37>;tag=005f869051f9000232ec81ce-220800a2 :1000 REFER::005f8690-51f90002-5595771d-3248496c@172.16.10.37
1474 NOT Feb 27 15:02:04.220936 (538:915) JAVA-SIPCC-SIP_MSG_RECV: ccsip_dump_recv_msg_info: <172.16.50.3:0 >:202 Acc: "Na2b R2es far3 elnozom" <sip:4015@172.16.10.37>;tag=005f869051f900033f8843ed-771a8b5c :1000 REFER::005f8690-51f90003-3b1d33e0-736f701b@172.16.10.37
1475 NOT Feb 27 15:02:04.224874 (538:915) JAVA-SIPCC-SIP_MSG_RECV: ccsip_dump_recv_msg_info: <172.16.50.3:0 >:202 Acc: "Na2b R2es far3 elnozom" <sip:4015@172.16.10.37>;tag=005f869051f9000441a8725b-40837788 :1000 REFER::005f8690-51f90004-0b47a177-200a5902@172.16.10.37
1476 NOT Feb 27 15:02:04.308774 (1644:1644) dgetserver-dgetserver.RESULT [_0_ [PASS] No error
1477 NOT Feb 27 15:02:04.341400 (325:333) PWRMAN-setMode(): NORMAL
1478 NOT Feb 27 15:02:04.341980 (538:585) JAVA-Calling handlePowerManEvent
1479 NOT Feb 27 15:02:04.342255 (538:585) JAVA-Calling handlePowerManEvent
1480 WRN Feb 27 15:02:04.345795 (538:914) JAVA-Thread-5|DisplayTask:? - resetCurrentPowerState(): Energywise is disabled
1481 DEB Feb 27 15:02:04.357759 kernel: [ 106.725866] Set LCD backlight 1
1482 DEB Feb 27 15:02:04.357881 kernel: [ 106.729986] Set LCD backlight 1
1483 NOT Feb 27 15:02:04.349092 (325:333) PWRMAN-setMode(): NORMAL
1484 WRN Feb 27 15:02:04.349855 (538:914) JAVA-Thread-5|DisplayTask:? - resetCurrentPowerState(): Energywise null domain
1485 WRN Feb 27 15:02:04.350312 (538:914) JAVA-Thread-5|DisplayTask:? - resetCurrentPowerState(): Energywise null secret
1486 ERR Feb 27 15:02:04.351167 (538:914) JAVA-[API]LED ID error
1487 NOT Feb 27 15:02:04.354951 (538:915) JAVA-Thread-7|JPlatUi:setUnregReason - old-unregister-reason:25, new unregister-reason:25, cc-server-type:0
1488 NOT Feb 27 15:02:04.355684 (538:915) JAVA-Thread-7|JPlatUi:isThisFailureFromNewCause - old unregReason =25 newUnregReason=25 unregReason ignored
1489 NOT Feb 27 15:02:04.358553 (538:585) JAVA-Calling handlePowerManEvent
1490 NOT Feb 27 15:02:04.358828 (538:585) JAVA-Calling handlePowerManEvent
1491 WRN Feb 27 15:02:04.359499 (538:914) JAVA-Thread-5|DisplayTask:? - resetCurrentPowerState(): energywise is not available now
1492 NOT Feb 27 15:02:04.360018 (538:914) JAVA-Thread-5|cip.cfg.TimeDateProperty:setTime() - nativeTimeProperty.commit() failed, timeshift = 668
1493 NOT Feb 27 15:02:04.376560 (538:915) JAVA-Thread-7|JPlatUi:setUnregReason - set to unregister-reason:25 after phone registered
1494 NOT Feb 27 15:02:04.424080 (302:302) downd-SOCKET accept errno=4 "Interrupted system call"
1495 NOT Feb 27 15:02:04.637387 (538:915) JAVA-Thread-7|cip.sipcc.SipEnhancedAlarmInfo:setLastDeregistrationReason - new unreg-reason=25(LastTimeInitialized), old unreg-reason=25
1496 NOT Feb 27 15:02:04.646543 (538:915) JAVA-Thread-7|cip.sipcc.SipEnhancedAlarmInfo:getLastUnregistrationTimeReason - TimeStamp=1582808524637; Reasons =25
1497 NOT Feb 27 15:02:04.648130 (538:915) JAVA-SIPCC-UI_API: ui_update_registration_state_all_lines: ***********ALL LINES UN-REGISTERED****************
1498 NOT Feb 27 15:02:04.649656 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener: - lineNotify():mgmtState=MGMT_REGISTERING(4) line=1 registered=false inService=true regRequired = true
1499 NOT Feb 27 15:02:04.651640 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : DND
1500 NOT Feb 27 15:02:04.656615 (538:914) JAVA-SIPCC-SIP_DEVICE_MGR: registration_processEvent: Event EV_CC_INSERVICE, current State MGMT_STATE_REGISTERING
1501 NOT Feb 27 15:02:04.656767 (538:914) JAVA-SIPCC-SIP_DEVICE_MGR: setState: new registration state = MGMT_STATE_REGISTERED
1502 NOT Feb 27 15:02:04.657195 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : STATE
1503 NOT Feb 27 15:02:04.658110 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - ccReady called...mgmtState=MGMT_REGISTERING(4), deviceEvent:1, nativeSideInitialized:true
1504 NOT Feb 27 15:02:04.658843 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - initializeLinePlane called...
1505 NOT Feb 27 15:02:04.660033 (538:915) JAVA-SIPCC-UI_API: ui_set_ccm_conn_status: ***********CUCM 172.16.50.3 ACTIVE***********
1506 NOT Feb 27 15:02:04.660369 (538:915) JAVA-SIPCC-UI_API: ui_set_ccm_conn_status: ***********CUCM 172.16.50.3 ACTIVE***********
1507 NOT Feb 27 15:02:04.680726 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener: - initializeLinePlane(): Mgmt Interface is in Service now..
1508 NOT Feb 27 15:02:04.682466 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - calling initializeLines...
1509 NOT Feb 27 15:02:04.682771 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - initializeLines called...
1510 NOT Feb 27 15:02:04.683229 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - returned from InfogetLines...
1511 NOT Feb 27 15:02:04.683473 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - entering line loop...
1512 NOT Feb 27 15:02:04.683747 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - instidx=0 inst=1 calling getLineInfo.....
1513 NOT Feb 27 15:02:04.684510 (538:915) JAVA-SIPCC-UI_API: ui_is_server_side_adr: server side application dial rules set = 0
1514 NOT Feb 27 15:02:04.693148 (538:915) JAVA-SIPCC-SIP_MSG_RECV: ccsip_dump_recv_msg_info: <172.16.50.3:0 >:REFER s: <sip:4015@172.16.50.3>;tag=1892967648 :101 REFER::59164a00-e571bdcd-32579-33210ac@172.16.50.3
1515 NOT Feb 27 15:02:04.723210 (538:917) JAVA-SIPCC-RCC_INFO: 0/0, rcc_receive_request: SUB 458756: REQ=35
1516 NOT Feb 27 15:02:04.841202 (538:915) JAVA-SIPCC-SIP_MSG_SEND: ccsip_dump_send_msg_info: <172.16.50.3:5060>:200 OK^M: <sip:4015@172.16.10.37>;tag=005f869051f90006780d03c2-341c685a :101 REFER::59164a00-e571bdcd-32579-33210ac@172.16.50.3
1517 NOT Feb 27 15:02:04.917472 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - initializeLine called: ref=41206536 lineFeature=9 button=1
1518 NOT Feb 27 15:02:04.918937 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - returned from InfogetFeatures...
1519 WRN Feb 27 15:02:04.919212 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener:? - features is empty...
1520 NOT Feb 27 15:02:04.919853 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter: - UpdateMgmtState [MGMT_REGISTERING(4)] --> [MGMT_REGISTERING(4)]
1521 NOT Feb 27 15:02:05.001831 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter$CcMgmtListener: - lineNotify():mgmtState=MGMT_REGISTERING(4) line=1 registered=true inService=true regRequired = true
1522 NOT Feb 27 15:02:05.012757 (325:333) PWRMAN-setMode(): NORMAL
1523 NOT Feb 27 15:02:05.013123 (538:585) JAVA-Calling handlePowerManEvent
1524 NOT Feb 27 15:02:05.013367 (538:585) JAVA-Calling handlePowerManEvent
1525 DEB Feb 27 15:02:05.050663 kernel: [ 107.397070] Set LCD backlight 1
1526 NOT Feb 27 15:02:05.035800 (538:898) JAVA-configmgr MQThread|ConfigManager:? - --->ConfigManager PropertyChanged: device.settings.fullyregistered
1527 NOT Feb 27 15:02:05.036654 (538:898) JAVA-configmgr MQThread|ConfigManager:? - <---ConfigManager PropertyChanged: device.settings.fullyregistered
1528 ERR Feb 27 15:02:05.043430 (538:906) JAVA-set_sys_console: error opening/dev/console
1529 NOT Feb 27 15:02:05.053105 (538:914) JAVA-Thread-5|cip.sipcc.SipEnhancedAlarmInfo:propertyChanged - name=device.settings.fullyregistered value=true
1530 NOT Feb 27 15:02:05.055669 (538:914) JAVA-Thread-5|cip.sipcc.SipCcAdapter: - UpdateMgmtState [MGMT_REGISTERING(4)] --> [MGMT_REGTD(5)]
1531 NOT Feb 27 15:02:05.079108 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : SERVER_STATUS
1532 NOT Feb 27 15:02:05.103036 (538:914) JAVA-SIPCC-SIP_CC_PROV: ccsnap_gen_deviceEvent: event type : SERVER_STATUS
1533 NOT Feb 27 15:02:05.127086 (538:893) JAVA-mediacontrolui MQThread|cip.msui.MediaControl$3:execute - [TR] executing the state-event handlerFunction=NoAudioRTPTxSessionEndedFunc
1534 WRN Feb 27 15:02:05.207904 (538:894) JAVA-callagent MQThread|DisplayTask:? - Line 1 property added with dn 4015
anish.gupta11
Were you able to find the resolution or reason for this??
I am experiencing the same issue
