03-22-2017 01:53 PM - edited 03-17-2019 09:52 AM
Can a 7832 conference phone register using MRA?
Solved! Go to Solution.
03-22-2017 02:15 PM
7832 is meant to be used with Spark, not with CUCM/MRA
http://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-7800-series/datasheet-c78-738318.html
Call-Control Support |
Cisco Spark Call |
● This conference phone can only be enabled through Cisco Spark Cloud for easy deployment
03-22-2017 02:15 PM
Cisco Spark Call |
06-19-2017 10:25 AM
Is this really true? ... A $1200 Cisco IP phone, and it can't be used on CUCM?
Is that why I can't find a CUCM device pack for it?
I would think for that price it would be able to handle either system.
Seems kind of bizarre to me.
How many phones are like this? Is there some way to spot them without combing through the data sheet?
06-19-2017 10:28 AM
Yes, as explained in the data sheet.
You can approach your SE/AM and provide this feedback so the BU can consider it.
09-13-2017 11:12 AM
The 7832 should be able to register with CUCM soon, I hope. They had indicated that the support would be coming in Q3, and it appears that they have posted the firmware that can be installed to CUCM now. I think the only thing I don't see to get this working right now is a device pack. It doesn't appear to be included in 11.5 SU3.
