7861 IP Phone - Incoming Call Alert - Multiple DN's
tim terry
Issue:
when there is a incoming call the 7861 phone will have the following display.
"Incoming calls on Lines"
7 incoming calls
answer, decline, ignore - tabs
_________________________________________________________________
At this point everyone has to press the ignore softkey to display the caller ID.
My question is, can this alert be disabled? I don't have 7 incoming calls, what I do have is one call coming in on 7 lines, and my line will always be one of them.
My setup is as follows.
Phone is configured with 7 DN's.
Each DN is in a line group, set for broadcast.
Primary line is set for ring, each additional line is set for flash.
The phones do not have a dedicated DID Line, only one DID for the site.
DN 26601
DN 26602
DN 26603
DN 26604
DN 26605
DN 26606
DN 26607
__________________________________________________________________________________
I currently have the following configuration.
Phone:7861
Phone Load:sip78xx.11-5-1SR1-1.loads
CUCM 10.5.2
Dennis Mink
from a cucm's point of view it is "broadcasting" 1 incoming calls to a single phone that has all the members of the line group on it as an extension. so it forks 7 calls set up requests to 7 extension, becuase you configured borad cast on the Line group.
I suggest you change your hunting algorythm to top down.
cheers
Please remember to rate useful posts, by clicking on the stars below.
broadcast is the only thing that works for this situation.
top down would never reach any phone after 4 before it times out to voicemail, it would be to long for a customer call to wait to get answered.
circular and longest idle have a similar issue.
you would think use prime line would tell the phone that ignore every other line except mine when it rings.
or a setting like Actionable Incoming Call Alert, that would suppress the notification that 7 incoming calls are coming in. and let the primary line display.
or a way to set a priority of the line, a filter or something.
looking for alternatives....
thanks
tim
