IP Telephony and Phones
Labels
Hi I have a SIP trunk connected to H323 gateway , that registered to cucm 11. the SIP is 100 lines , each two lines will serve one company  and there are two operators for all companies, I need to help the operators to differentiate between the comi...
Hi, Please i need some help on one-way issue experiencing whenever i try to migrate a third-party switchboard device to route calls through our new SIP gateway. New SIP provider will accept only G729 but preferred MTP on third-party SIP trunk to CUC...
Hi Experts, We have an issue here with unity 10.5. The scenario is when some one call the queue ( UCCX 10.5 )and after the queue wait time exceeds the configured limit for example 2 minutes , then they will get an option to leave a message. It works ...
S N by Level 1
  • 704 Views
  • 5 replies
Hello Community, I have tried to upload some costum images to CUCM, while updating the List.xml in order to change the Wallpaper, mainly on Cisco 8845, however I receive the error on the display "Unable to obtain additional wallpapers from server". ...
Dear, I have a one way sip trunk for incoming call from sip provider. and CUCM 10.5 and Contact Center 10.5 and 2911 router. my scenario is like this: CUCM(172.16.X.X)--------------(H323)---------(172.16.X.X)Router(10.X.X.X)---------(SIP)-----------...
Hi, I have configured SRTS as under: call-manager-fallback max-conferences 8 gain -6 transfer-system full-consult ip source-address 192.168.132.1 port 2000 max-ephones 5 max-dn 5 keepalive 20 CUCM configurations are attached. issue is that from...
