12-01-2014 06:12 PM - edited 03-17-2019 01:09 AM
Hi, we have installed serveral 7861 phones at a customer site and the voicemail button doesn't work. Dialing the voicemail pilot is ok. The other models of phones have no issue with the voicemail button.
I have played around with the voicemail profile on the line setting and still no luck. It must be a simple config issue somewhere but can't seem to find it!!
The 7861 phone is running sip78xx.10-2-1-12ES1 (to get around the XML error)
CUCM is 9.1.2.10000-28
It didn't work on 8.6.2.24900-17 either.
Any help would be much appreciated.
Cheers,
Mike
12-01-2014 06:41 PM
Hello Mike,
Did you check the voicemail profile has the voicemail pilot number associated to it?
Do you get any error while pressing the message button from Phone or it do nothing?
Br,
Nadeem
12-02-2014 11:25 AM
Hi Nadeem,
The voicemail profile does have the voicemail pilot number associated to it. It is working on all other models of phone.
No errors when pressing the button. Nothing appears on the screen. It's just a blank key.
Mike
12-02-2014 12:36 PM
Did you check the line itself as I had mentioned? The voicemail profile should be applied to the line above the CSS.
12-02-2014 01:56 PM
Hi Brandon, yes i have changed the voicmail profile. Tested with default and also with the actual voicemail profile name. Still no luck.
The phone model 7861 is SIP. All the other phones are using SCCP and work fine.
12-02-2014 02:05 PM
The SIP phones to have access to the voicemail via CSS right? Trying to think of why the button itself wouldn't do anything since all others are working.
12-02-2014 02:07 PM
Yes they do as they can dial the voicemail pilot with no issue.
04-05-2016 01:36 AM
Does it happen on one phone or all the 88XX phones?
Try this:
Apply the default profile to the line of the phone.
Copy the current "default" profile and make a new profile.
Make the new profile as the default profile and reset the phone.
Now make the old profile as the default profile and reset the phone again.
Test it and let me know.
Please rate if helful
~Amit
12-01-2014 07:54 PM
Make sure the new phones are set to use the Voicemail service. I know this might sound like it should be default but it is something to check. Also, check on the line of the device and make sure the phone is setup to use voicemail and not set to None or whatever the default is.
07-30-2015 02:09 PM
Did you ever find resolution? I am having the same problem with the voicemail button on an 8851 phone, we are on CUCM 10.5
SP
07-30-2015 02:16 PM
Hi Sarah,
Can you dial the Voicemail Pilot number and see if it works?
07-30-2015 02:19 PM
I found the problem.....all other phones have the voicemail profile set to <none> which uses the default, these phones needed to have a specific profile selected
04-04-2016 12:39 PM
Actually on this SIP models and also on 8851 voicemail key doesnt work until it has a message, leave a message on that DN and try the key it should work if VM profile its correctly configured
