7914 sidecar on 7965
chris_thomas1
Will the 7914 sidecar work on a 7965 phone? CUCM Version 10.5.1. I programmed it but when you press a button the sidecar goes blank
vijit kumawat
Make sure it has proper phone button template for sidecar.
Bill Mungaven
Yes, the 7914, 15 and 16 will work with a 7965.
You can tell which modules are supported on multi-button sets by clicking the dropdown list in the Expansion Module Information section of the base phone configuration page.
Bill
Thank you for the answer.
