06-22-2015 11:47 AM - edited 03-17-2019 03:25 AM
Hi Experts,
In my project PO, there is 7965G IP phone for reception and 7916 expansion module, My question is there is no power adapter for 7916, I have just PoE from 2960s switch, Do I need extra power adapter for 7916 when connect to 7965G?
Mohammad Saeed
06-22-2015 12:36 PM
Hi Mohammed,
The expansion module will get the power from PoE switch along with the phone. You don't need separate power adapter.
*** Please rate useful posts
06-22-2015 12:49 PM
Hi Mohammed
have you tried it before? because I connnected with the phone but did not work!
06-23-2015 12:02 AM
Guys, I think I was wrong. I had it in my office but never realized that it was connected with power supply. Usually the IT support connects the phones. Just visited one of the desks and confirmed that it needs power supply.
Sorry for the confusion.
06-22-2015 12:55 PM
I saw Mohammed's posting after my posting, so I started doing a little research and I haven't located any Cisco doucmentation concerning a 7916 behind a 7965G connected to a 802.3at poe switch, however a 7965G uses 802.3af only, so I don't believe it will work. I'm still searching for a definite answer.
06-22-2015 12:41 PM
Hello Mohammad,
According to the 7916 phone guide, If your phone is powered via poe, then yes you need a power supply with one or two 7916 expansion modules. It is a separate orderable items.
See link for more info.
http://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cuipph/7916/english/16enug.pdf
Power over the Ethernet to your Cisco Unified IP Phone
| With one or two Expansion Modules, you need a power supply unit (separate orderable item).
Power supply to your Cisco Unified IP Phone
| With one Expansion Module, you do not need a power supply unit. With two Expansion Modules, you need a power supply unit (separate orderable item).
Hope this helps,
Please rate helpful posts.
Thanks.
