IP Telephony and Phones
Labels
Hi,We're running CUCM 9.1 - I want to be able to remove just the phone line from 150 phonesbut leave the line/extension in place on the Device Profile. So effectively the phone no longerhas a line/extension on it and the user has to login to be able ...
Hello, Just found after a recent upgrade to 10.5.1 that in a Hunt Pilot Configuration under the Hunt Cal Treatment Settings I am not able to send a call a Unity Mailbox. Prior to the upgrade the HP was configured to Fwd busy and no answer calls to *5...
Cisco Ip phone -->CUCM--(MGCP)--3945 Gateway/ E1 -->Service Provider.  When we make an outbound calls from Cisco phones, calls getting connected properly but when the called party disconnects the calls, we see the calls disconnect but Call timer is s...
We have a Unity 7 voicemail server and are planning an upgrade to our entire phone system next year. I need more licensing right now due to some new positions. Is there any way Cisco can help me? The licensing I need is UNITY7-USR-E. Is there a good ...
amtacisco by Level 1
  • 311 Views
  • 1 replies
Hi All,This is a CME Solution.CME -> SIP trunk-> CUCM -> PSTN.The configuration on CME is ment for sip-notify.When normal calls are made sip-notify are seen to be used.But when calls to IVR are made below is the DTMF method found to be used.Any reaso...
