7931 Button Assignments
We are utilizing 3945 routers with CME and 7931 phones. The default template sets all phone lines to the bottom of the phone, and speed dials above them. Is it possible to set phone lines and speed dials to specific buttons, and not just all starting from the bottom, and some buttons blank? For example, phone line 1 to button 20, and speed dial 1 to button 8, and button 7 blank?. We are not using the GUI at this time, so we don't have access to that to try. All of our programming has been through the command line.
Thanks in advance for any feedback.
Vaijanath Sonvane
Hi Scott,
What version of CME are you using? Are you using SIP or SCCP for Cisco 7931 Phones?
Vaijanath
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
We are using CME 9.5, and SCCP.
