7931G button transfer call
Hi All,
I have a configuration problems with a new CCME system: router 2811 (firmware: 12.4.15T1 + n. 23 IP Phone 7931G firmware: SCCP31.8-2-2SR1S.
The problem is during transfer call from a internal number e.g. 101 and another internal number e.g. 102.
I explain the case:
Internal number e.g.: 101, 102 and 103.
From IP phone 101 I call 102 using button 2, (on all IP Phone I have assigned an internal number for each button, e.g. on my IP phone: 101 on 1 button, 102 on 2 button, etc), and after 102 has answered I try to transfer the call, pushing ?Transf? button on IP phone and then push 3 button (103). The call has transferred directly without the possibility to consult the person (103) before to transfer call. If I call external number and then I try to transfer it to e.g. 103 from my Ip phone (101) the call has immediately abort.
Note: If I use for transfer the call the phone keyboard or to be more precise, I digit 103 number on the keyboard instead of to push button 3 directly, the call has transferred correctly after I have consulted the 103 person and he has accepted the call, pressing ?transf? button again.
This sequence works very good on IP Phone 7960 system.
Can you help me?
Do you know where could it be the problem?
Follow a part of the router configuration:
telephony-service
load 7931 SCCP31.8-2-2SR1S
max-ephones 35
max-dn 60
ip source-address 192.168.168.4 port 2000
timeouts interdigit 7
url directories http://192.168.168.2/fw/apps/Speedy/xml/directory.asp
url authentication http://192.168.168.2/fw/authenticate.asp
user-locale IT
network-locale IT
time-format 24
date-format dd-mm-yy
max-conferences 12 gain -6
moh music-on-hold.au
web admin system name admin password router
dn-webedit
time-webedit
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 101
pickup-group 100
name Savina C.
no huntstop
transfer-mode consult
ephone-dn 2 dual-line
number 102
pickup-group 100
name Pina C.
no huntstop
ephone-dn 3 dual-line
number 103
pickup-group 100
name Antonella I.
no huntstop
ephone 1
mac-address 001B.D46C.3DF7
ephone-template 15
type 7931
button 1:1 2m2 3m3 4m4
button 5m5 6m7 7m8 8m9
button 9m10 10m11 11m12 12m13
button 13m15 14m16 15m17 16m18
button 17m19 18m20 19m23 20:60
ephone 2
mac-address 001B.538E.F345
ephone-template 15
type 7931
button 1:2 2m1 3m3 4m4
ephone 3
mac-address 001B.538E.F50A
ephone-template 15
type 7931
button 1:3 2m1 3m2 4m4
Thank you for best support
Best Regards
Antonino
Rob Huffman
Hi Antonino,
Maybe this is what you are looking for;
Consult Transfer Support for Direct Station Select
For CME 3.2 and later versions, consult transfers can take place during direct station select. The default behavior is a blind transfer. Direct station select is a functionality that allows phone users to transfer calls to idle monitor lines. A monitor line is a line that is shared by two people. Only one person can make and receive calls on the shared line at a time, while the other person, whose line is in monitor mode, is able to see that the line is in use.
Consult transfers to monitor lines are performed with the following steps:
Step 1 Answer the incoming call.
Step 2 Press the Trnsfer (transfer) soft key.
Step 3 If the monitor lamp is off, press the monitor-line button.
Step 4 Announce the call.
Step 5 Place the handset on hook or press the Trnsfer soft key a second time to transfer the call.
If the person sharing the monitor line does not want to accept the call, the person announcing the call can reconnect to the incoming call by pressing the EndCall soft key to terminate the announcement call and pressing the Resume soft key to reconnect to the original caller.
Direct station select consult transfer is enabled with the addition of the dss keyword to the transfer-system full-consult command, which defines the call transfer method for all lines served by the router.
So you need this setting;
**transfer-system full-consult dss
Hope this helps!
Rob
Rob Huffman
Hi Antonino,
Hope this helps!
Rob
