01-07-2011 11:45 AM - edited 03-16-2019 02:45 AM
I have a SF 300-24P (new one) I try to connect a 7940 or 7960 IP phone but they are not powered, if I connect 7911, 7970 they are powered without problem.
Should I configured something in the switch or these model are not supported??
Solved! Go to Solution.
01-08-2011 09:05 AM
The 7940/7960 used Cisco pre-standard PoE which I doubt that switch supports.
01-08-2011 09:05 AM
01-08-2011 12:31 PM
Hi Jonathan,
Thanks a lot for your response.
regards
