7940G, SIP, not registering? phone icon + x
myphonepain
The LCD phone icons show with a little 'x' to the right: [phone] x
line 1: callcentric.com, line 2: voip.ms
SIP settings I've changed from using FQDN to IP address for proxy
line 1
name: [10 digit phone]
short name: home
auth name: 1777xxxxxxx [callcentric id]
auth password: [sip extension password NOT web account password]
display name: matt
proxy address: callcentric.com
or
proxy address: 204.11.192.160
proxy port: 5060
or
proxy port: 5080
(call centric supports sip port range 5060-5080 (I use the even numbers since not SIPS))
save, then these on screen messages:
configuring ip
requesting configuration
__firmware version
application load ID
P0S3-08-8-00
boot load ID
PC030301
DSP load id
4.0(2.0)[A0]
__status messages
E102 misc: no time server
W351 unprovisioned proxy_emergency
W35 unprovisioned proxy_backup
I hear dial tone but I suspect that would be phone generated no matter what.  There are no errors on dialing.  Dial, then lots and lots of DEAR air.
paolo bevilacqua
Here, only Cisco call platforms are discussed.
For third-party application, you should seek support from the ITSP, or try forums like voip-info.org
