7941/61 SIP phones on 3th Party IP PBX
perryvdb
For the 7940/60 there is a clear description of what you need and have to configure. For the 7941/61 it isn't. Can somone help on the right documentation??
paolo bevilacqua
the configuration tags in the XML file are the same. The phones may behave differently depending on the FW version, but configuration is the same.
Thx, w'll try
