7941 display ???
DebbyHill
I have a 7941 phone that is showing ??? over the the left side of softkeys and when it rings it only gives a chirp then no more ringing. Any ideas on how to fix this or what the issue might be? I have reset it in the CM, reset it manually and still shows and does the same thing.
Rob Huffman
Hi Debby,
I've had similar issues before that could only be solved by physically
disconnecting the IP phone from the port/jack waiting 30 seconds and
re-connecting. Have you tried that
Cheers!
Rob
I had tried that one also and it didn't work, finally just switched out the phone with a 7961.
Thank you for your comment!
Thank you,
Debby Hill
North Kansas City Hospital Telecommunications
office: 816-691-5456
fax: 816-346-7436
hrs. 7a-3:30p
