08-11-2011 04:51 PM - edited 03-16-2019 06:26 AM
Imagine an admin with 6 exec line appearances on her phone. Caller calls Exec A and the admin answer.
She normally take a message but in this case the caller specifically wants to go to Exec A's voice mail.
Is there a way to do that? Am I missing something obvious?
Solved! Go to Solution.
08-11-2011 05:00 PM
Add a CTI RP with *XXXX and CallFwdALL to Voicemail
But make sure your default voicemail profile has mailbox mask XXXX listed or this won't work
so if the Exec A number it 1000 yu can dial *1000 then the call wil go to VM of number 1000 assuming the mail box mask created with XXXX so the * get removed
if helpful Rate
08-11-2011 05:00 PM
if helpful Rate
08-11-2011 05:33 PM
Bingo! All good. Thank you.
